Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: 915 transmission question...
  1. #11
    Oct 2012
    Minneapolis
    To check the coupler bushing, move the gear selector and hold the shaft going to the box. check for free play, there should be almost none.
    maaaaybe it has a millimiter of play front to back. none from left to right.
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
  2. #12
    Sounds good, as much as you may hate it, don't know why, try some swepco and see what happens.
    It really was THE only lube for the older boxes before Kendall came along. I've got around 145k on my box with no rebuilds so, to say the least, it's worked for me.
  3. #13
    Oct 2010
    Southern Ca.
    New bushings in the shift coupling that are tight will amplify transmission noise . Tight bushings left to right will also lightly preload the shift forks and create some noise .
  4. #14
    Solid mounts will amplify noise, as mentioned earlier. So will incorrect adjustment procedure, what was your adjustment method?
  5. #15
    Oct 2012
    Minneapolis
    per wevo spec I guess. 3rd gear....move some sh$t. etc...The shifter itself interacts with the transmission fantastic imho. The wevo shifter is easily the best thing I've bought for the car.
    its funny, as time goes on here, I'm feeling like taking the wevo mounts out, and putting the seats back in the rear with the rear parcel shelf panel area thing too. Try to find a compromise.
    went for a drive with a friend yesterday, said its nothing to worry about. I put some 80/90 in and really notice virtually no difference in sound or whine over the synthetic. gear selection feels a bit "rounder" I guess. Less notchy I think it would be described.
    When I get home at night and its late, I turn the car off, hit the clutch and roll into the driveway so I dont wake up the kids. oddly, it still make the sound but very slowly, ttinktinktinkink tink tink tink...tink...tink.........tink...stop. maybe thats a different sound. I dont know. either way the rattle while driving is probably just 915 noise amplified by as said, wevo mounts, new coupler, and a missing boot in the back seat.
    I'm just glad to discover its not the engine, which still runs great. It has developed a leak, but at the junction on the oil line thats just above the line that goes to the oil cooler on the right side. thats kind of a bummer as the heat exchangers have to come off to replace. Apparently I was supposed to replace it when I rebuild the motor. Who knew.
    Here is my audience whilst changing the gear oil last night. We hang out every friday night. I took flack the entire time. Nice guys. :P
    -Kris Clewell
  6. #16
    Kris I didn't realize you had a Wevo shifter,,,,,so telling you how to adjust a factory shifter to eliminate noise isn't going to matter.
  7. #17
    what color are the wevo mounts?
    - you have 2 or 3 different options for softer mounts, depending on the color of the current ones
    besides that, you can set the softness of the front mounts and rear mounts differently
    also did you replace the bushings on the shift tube and shift ball?
  8. #18
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Richy View Post
    Bingo! Richy, udaman........
    Jim
  9. #19
    Oct 2012
    Minneapolis
    thanks for the input guys. wevo mounts are the black. I'm thinking of going stock.
    -Kris Clewell
  10. #20
    Quote Originally Posted by Kris Clewell View Post
    This isn't a shifter adjustment noise, or trans mount bushing material issue, imo.
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
