Results 1 to 7 of 7
Thread: Brake Fluid Overflow Line
    I'm trying to run a new brake flow overflow line, my old one had broken off.
    I can't find which hole I should use to route out of the trunk compartment.
    This is for a 73S. Any ideas?
    Dave, the top left side bumper bracket access hole should have a rubber grommet the hose goes thru, the other three are plastic. (basically behind the reservoir bottle)
    Thanks Ed, I was hoping you were around.
    Sep 2006
    San Francisco
    If you need to buy one, the P/N is superceded to 021119569A. They are still available.
    Jeff Jensen
    Thanks Jeff, good to know. I think I may have it in one of my boxes.
    finally I know where this belongs!
    Oct 2010
    Southern Ca.
    I'm used to seeing the overflow line exit through the bottom hole .
