Thread: Glove box door switch wire routing on a '69
    Hi all-
    How is the wire routed from the front trunk harness to the switch the door actuates? There are no apparent holes near the switch for the wire (and spade connector).
    Thanks a lot for your help in advance!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    It uses a wire that comes off the harness that goes to the fresh air blower and switch, so it comes from under the dash, not through the firewall.
    Hope that helps..
    Mark..
    Yes, that helps. Thanks Mark!
    Cheers,
    Ron
