Results 1 to 10 of 13
Thread: What kind of plastic is the fuel bleeder tank attached to headlight bucket?
    Attached to headlight bucket in wheel well. Mine is cracked and they are NLA. Tried the used route too, but no love. I'm stuck with trying a repair this one and need to know if it's polyethylene or something other to get the right repair. Thanks
    1973 S Targa #0098
    Member # 1498
    I would take it off the car - clean it up well and use a two part epoxy - that should work - likely an injection mold made part
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    I agree, the only thing that "might" stick is a jb weld type epoxy. Although I think it was either a blow mold or centrifugal mold type polyethylene.
    Feb 2011
    Northern VA
    Isn't it polypropylene or similar? Plastic weld it.
    Atlanta, GA
    I bought a used one from DC auto. Mine too had cracked?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    There is a company in the process or re-producing these. I'm not sure how long until they are to market...FYI
    1969 911 E #824
    Atlanta, GA
    Quote Originally Posted by xpensivewino View Post
    Who is the company for the records?
    Mark Erbesfield
    1957 356A #58648
    Backyard procedure: you can weld it with a hot butterknife and some scrap polyethelene from another part or a rental kayak. get all fuel vapor residue out first. S
    Apr 2011
    N.Calif., south of SF
    Had mine out about a year ago. Had one small pin hole that I simply filled with clear silicone. The outside cleanup was done with multiple products, always being careful that the cleaning product wouldn't melt the container. I finally lightly sanded some dark areas that really improved (removed) most stains. I finally lightly sprayed it with a satin clear.
    While I was there I wire wheeled the retaining strap and painted. Installed with new fasteners.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Quote Originally Posted by merbesfield View Post
    I'm not sure of the company, I just know someone in the industry who had told me it's in the works, due to the fact that every original one is cracked. I'll try to find out who it is and when it's coming to market..
    1969 911 E #824
