Results 1 to 8 of 8
Thread: Wiring diagram '73
    Junior Member
    Jan 2010
    Ann Arbor
    Wiring diagram '73
    Where can I find a large wiring diagram for a '73T w/sunroof? Got lots of loose hanging wires to ID.
    There is a color wiring diagram in one of the factory volumes....I don't recall exactly which volume or if it was in one of the supplements...it is a little hard to read....so making a blown up copy for your shop will save your eyes and your original from any harm...If you need one, I am sure a "wanted to buy" ad in the proper section will result in an original coming your way
    I downloaded one. Try Pelican, or Rennlist
    Feb 2012
    Kolham, Groningen, The Netherlands.
    We can help you, just send some picture's of your loose wire's to info@kroonwireharnesses.com and we will tell you were to connect them.
    We also have all diagrams available.
    Regards from the Netherlands,
    Gerard Kroon
    www.kroonwireharnesses.com
    Jan 2009
    Cape Girardeau, MO
    Try the link below. SL35 is probably your best bet. I had one blown up to 24x36 and laminated at a Staples and it's been worth every penny.
    http://members.rennlist.org/911pcars/WiringDiag.htm
    1971 911T - 3.0L with PMO's - Light Ivory - Gretchen
    Quote Originally Posted by TommyV View Post
    Did the exact same Staples run and have them framed and hanging on my garage wall...very easy to see and trace wires with the color enlargement.
    Junior Member
    Jan 2010
    Ann Arbor
    All,
    Many thanks for all your responses.
    Tom M
