timely question.
I've done this a number of times and am working thru it right now.
On various cars I've had over the years, I've found different anodizing and different materials, each of them respond to a variety of techniques, but I never know which is best until I dig in.
I've used acetone, paint thinner, sometimes even rubbing alcohol is enough to remove some black paint that previous owners have applied.
for deep anodize removal, something lye best is needed....but the concentration varies from piece to piece.
I've used drain cleaner (the most caustic you can buy, hair and grease removal, typically found in a black bottle that comes in a zip-lock bag in the big box stores).....I've used royal purple cleaning spray, seems gentler, and I've used the yellow ez-off oven cleaner.....
and then polish, mag wheel cleaner, mothers brand is my choice, flitz metal polish is pretty good, too, or any of the specialty brands from eastwood, or others.
some say rubbing it down with WD-40 will preserve the shine, I prefer a wax every six months (mothers wheel wax is a good choice).
I'm working on a project now, where I'm removing the black anodize from some trim, and this kit came highly recommended, although pricey for what it is....
https://mercedessource.com/store/ano...estoration-kit
good luck and let us know how you proceed and how the results stack up.
