Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: FS: 1969 Porsche 911 T
  1. #11
    Oh, don't know phone codes.. Thank you! Makes things complicated.
  2. #12
    Jul 2008
    South Florida
    This car has experienced quite a transformation!
    Update: https://www.thebarnmiami.com/vehicle...porsche-911-rs
    Now presented as "1969 Porsche 911 RS 3.0 chassis #00004." (sic)
    "Fully documented nut and bolt restoration with only 50+ miles since completion, hotrod 3.0L RSR twin plug motor with fuel injected independent throttle bodies, and custom built engine management system. Full mechanical build by the renowned MGM Motorsports. Tuned to run on pump gas with 230 RWHP and 190 FT LBS torque at 7600 RPMS. 5 Speed differential transmission with limited slip and billet aluminum bearing plate. Transmission is geared for top speed of approximately 145 MPH. All trades welcome, even multiple cars! By Appointment only.""
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
  3. #13
    Senior Member ennisk1's Avatar
    Jul 2006
    Jupiter, FL
    It was at DRT when I last saw it. It was built by Marty Gilbert (MGM in Pompano). Marty is a great guy and knows his stuff as he used to work with Butch Stokes. He did the 2.2 liter motor in my first hot rod and that thing was strong.
    The car is ok, a little rough around the edges, but definitely a nice build. Too bad its set up as a "tribute"....thats so 2005. Price is stupid and it now has that Miami stink about it.
    Keith E.
    Early 911S Registry #941
    1978 911SC Dirty Penny
