Results 21 to 30 of 36
Thread: SCRS air cleaner cover
  1. #21
    Sep 2008
    Auckland , New Zealand
    Quote Originally Posted by Sun888 View Post
    Hi
    The fine meshed version looks terrific and I would love to replace my snorkel with it. Just wondering - and apologize if that is a question that has been discussed before, still very much on a learning curve here - wouldn't the swap to the SCRS style air cleaner cover change the amount of air the engine can suck in, i.e. more air? Wouldn't that have an impact on air-fuel-ratio etc.?
    good point , i have taken the assumption that if you replace the carb box on a 911 for high flow air cleaners they work better this mod will do the same to a lesser deg. plus the air is being taken higher and closer to the inflow so should be colder .
    without putting the car in a wind tunnel and smoke testing the flow i know of no definitive answer.
    look cool though
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  2. #22
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    John, I am running a filter inside and it's I.D. matches the O.D. of the wire mesh screen. The filter has a slight cone shape in the rear and allows more air to be pulled in around it compared to the front section.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
  3. #23
    Senior Member Sun888's Avatar
    Feb 2014
    Switzerland
    Did a little reading on how the MFI system works as the question I asked kept bothering me - which I actually should have done before asking the question.
    Writing this for all those who stumble over the same question - and apologizing to repeat what is obvious to those in the know - and without claiming to be an expert: basically, I was wondering how the MFI system measures air mass flow through the stacks and how that impacts fuel metering. Well, it doesn't. Contrary to carburetors, where the fuel metering is performed in direct proportion to the actual airflow, with the MFI the factors governing fuel delivery are engine speed and throttle opening - i.e. the airflow is not measured directly at all and fuel delivery is based on two mechanical inputs. Still being new to the MFI world, and being just a tinkerer, not a pro, coming from a car universe that until recently consisted of carburetted Alfas, MGs and BMWs, it simply didn't occur to me that air mass flow was not in the equation - so to speak. Got some further reading to do .... gonna be fun.
    Recommend reading for MFI-beginners:
    http://stuttgartperformanceengineering.com/mech_fi_sertup.html
    http://www.911mfi.com/index.html
    If there's an older thread here on the forum that explains all this: can I ask those who contributed to it to add the link.
    Sorry for hi-jacking the thread. To bring it back to the OP's topic: John, the wire mesh screen looks terrific. I'd want to run it with a filter inside the airbox but would still prefer a finer mesh. The one you've been running on your 73 looks perfect and I'll buy one once you start building them.
    '70 E Coupe Pastel Blue
    '73 S Targa Gold Metallic
    Registry #2890
  4. #24
    Sep 2006
    Bend, Oregon
    Painted the stacks and it does look better.
    Mark Jung
    MFI Werks
    R Gruppe #686
  5. #25
    Sep 2008
    right guys , sorry for the delay on these but 7 weeks ago my father was told he had cancer and has since passed away , so my time has been else where and just getting back on track now.
    I have most of the parts ready just waiting for a couple more samples to test final fit out of the air clear cartrageas i am trying to get a correct fit for those who will be using them.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  6. #26
    Jan 2014
    Le Mans, France
    Sorry for your loss, John.
  7. #27
    Junior Member
    Jun 2015
    Austin, TX
    Condolences, John.
    '72 911T 3.0 coupe Bahia
    '86 Targa Iris
  8. #28
    Junior Member
    Jun 2015
    Austin, TX
    Hey John -
    Anything new to report? I am a long ways from completing my motor build, but definitely will be wanting one of these as the cherry on top. I hope all is well.
    '86 Targa Iris
  9. #29
    Sep 2008
    Quote Originally Posted by jdbunda View Post
    Hey John -
    All components made and ready , just making the jig to put them together over the next week
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  10. #30
    Sep 2008
    Jig made , 2 sizes in mesh available ready to make to order
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
