Some VIN experts should head over to BAT and look at this car. quite a bit of VIN controversy and discussion of a possible rebody.
Early 911S Registry member#775
not in 1969.
What a frankencar. Hope the buyer is happy
Here it is ... http://www.early911sregistry.org/for...-hurry-to-sell
$75,000 obo, no hurry to sell is in the title of the post. This one was well received by the Bring a Trailer crowd for sure!
Bonhams Auction, Fernandina Beach Golf Club, Amelia Island, FL, March 8, 2018
1970 Porsche 911T 'Karmann' Coupe, Lot #148
VIN: 9110120196
Engine: 6550961
Trans: -
Color: White/Black
Mileage: 50,296 (indicated)
Auction Estimate: US$50,000 - 70,000/£36,000 - 50,000
Sold for: US$34,720 (including premium)
Auction Description:
*Prepared for Club or Vintage racing
*Built by Rothsport Road and Race
*930/Boxster brakes
*Light and very fast
*Consistent class winner
This 1970 911T Karmann coupe was restored for street use circa 1999/2000, and then converted to a club-level racing car in 2004/2005 by Rothsport of Tualatin, Oregon. The original 2.2-liter six was replaced by an extensively-modified high-compression 2.7 that develops 240 horsepower at 6500 rpm with Bosch mechanical fuel injection and street gas. The Type 915 five-speed gearbox was race-prepared with a limited slip differential and WEVO shifter. The tub has a full rollcage, wrap-around Sparco "containment seat" with competition harness, safety netting for the driver's window and to the right of the driver, a quick-release steering wheel, and an external electrical cut-off switch.
There are 930 Turbo brakes in the back and Boxster brakes in the front. A front oil radiator was installed, as was an 11,000 rpm tachometer, in-car camera mounts, and wiring for two-way radio communication. There are steel 911SC rear quarter flares and Lexan side and quarter windows, fiberglass engine cover and IROC-style whale tail, front and rear valances. The car is fitted with 16-inch-diameter replica Fuchs-style alloy wheels, 7 inches wide in front and 8 inches wide in back.
The current owner states that this car proved very successful in competition, recording numerous class victories. The car was retired from active racing in 2012, and placed into dry storage with about two hours of running time on the engine. Reportedly, the car is started and driven monthly, and all fluids have been changed on an annual basis by AR Auto in Lake Oswego, Oregon.
This car is supplied with its original Owner's Manual, an additional set of powder-coated replica Fuchs wheels, invoices from the race conversion, a racing logbook through 2012, and other documentation. Prior to returning to competition, the car will require recommissioning with new tires and racing harness. For the amateur racer who wants to dip a toe into production-car-based racing, vintage racing with the addition of a fuel cell, or as a very quick "hot rod" 911 for autocross or time-trial, this Porsche would be an excellent starting point.
Doug Dill
1973 911E Coupe
PCA #1987109761
Early 911S Registry #548
1972 Porsche 911 ST Kremer European World Champion Tribute
https://autokennel.com/1972-porsche-911-st-kremer/
Accurate Recreation by Marque Experts
2.5L Twin Plug High Butterfly MFI
Stock #0928
VIN # 91121xxxxx
2,800 Miles on Build
2,000 Miles on Engine
Viper/Emerald Green (225) on Black Interior
5-Speed Manual Custom Gearbox
PCA/Early S/R Gruppe Member Built/Owned
Offered at $249,990
Highlights of the build include the following:
All metal body including steel flares, bumpers, and hood
Aluminum deck lid
Fenders and bumpers modified to ST-look by John Esposito
Body correctly painted per factory methods
Painted livery stripes (sponsorship and gumballs are vinyl)
Repa “Y” vintage-style belts by Bill Rich w/factory sewn ID patches
Dash plaque signed by original race driver John Fitzpatrick
Parcel shelf harness anchors per factory specifications
ST roll hoop (bolted-in and cambered for driver safety on street)
Original “real” driver Recaro ST seat (passenger is early reproduction)
Factory ST lightweight seat mounting brackets
10k RPM tachometer/gauges restored by North Hollywood Speedo
Tiny rev limit light in clock blanks
Original Bosch battery kill switch mounted in dash speaker grill
Factory front RSR 9×15 Fuchs date stamped 3/73 (refinished by Weidman)
Custom rear 11×15 Fuchs built by Harvey Weidman
Custom oil cooling system per factory setup
Crossover hard oil lines through trunk
Large mouth (30mm) Behr dual vender oil coolers (1972 only)
Factory style custom fabricated cooler guards
Custom street exhaust system with similar factory outlet tips location
Additional race exhaust system for track use
Custom fabricated RSR-style sway bars using Tarett Engineering drop links
Gusseted front strut brace
ER polybronze bushings
Aluminum rear trailing arms with adjustable spring plates
Koni adjustable shocks
22mm & 28mm torsion bars
Bump steer extensions
Similar to the rest of the car, the motor was also built to what would have run in the day. Walt at Competition Engineering was hired to do the work. Highlights include:
2.5L short stroke built on 1974 7R magnesium case
90mm (10.5:1 compression) JE pistons and nikasil cylinders
Line bored case with upgraded case savers/time certs/shuffle pinned
Factory rods
66mm counterbalanced crank
Heads ported/polished/decked (39/36 I/E, 5 angle value grind)
High flow valve job with new guides, springs, and studs
Twin Bosch 6-pin CDI boxes
7,500 rpm rev limiter (by Norbert Kerle in Germany)
Original high butterfly injection system from Vasek Polak’s ’72 ST
GE 40 cams
RSR flywheel (balanced to crank, clutch, and pressure plate)
JB Racing twin plug distributor
Custom ITG air filter system
Stainless steel headers
Cabin fuel mixture control (next to e-brake/replaces heater lever) for easier cold starts
For the last few years/thousand miles, Moorespeed has done some key work on this ST to not only get it to run right, but to also make it a wonderful driving early longhood for the street. Over $40k was recently invested which included some of the following items:
Recammed the MFI pump (custom ground cam by Mark Jung/MFI Werks)
R&R high butterfly system and tuned to work properly
Installed custom cold start lever
Repaired misc. wiring
Reinstall roll bar to tilt and provide better safety for street use
Complete chassis inspection for safety
Adjust ride height for street driving and corner balance
Install original aluminum S brake calipers (reconditioned)
Custom mount driver seat low for tall drivers
Rebuilt Bosch starter
Repaired shifter housing
New clutch and rear main seal
Open transmission and replace main shaft seal
Reseal transmission (all new gaskets)
New shifter bushings
While engine was out, many seals and gaskets were replaced
Rebuilt distributor
Replace both front struts (RSR) and modify front control arms/ball joints
New rear RSR struts
New (2) Bosch CDI units and repaired wiring
New front wheel bearings (inner and outer)
Install horn
Finally, just a few months ago/100-miles, a full major service was performed, which included spark plugs, chain cover gasket, timing chain cover, valve cover gaskets, valve adjustment, oil service, and mount/balance a set of new Michelin TB15 Course tires.
-70 911E
-84 3,2 Sold
