Results 1 to 10 of 11
Thread: MFI tuning in north SFO bay area ?
    I'm tired of messing with my MFI - 90% there but not 100% ! My mechanic is superb for everything else, but I fear we're not making progress past 90% on the MFI tune. Everything is new (TBs, engine, plugs and wires, distrib, valves are adjusted).. Still in order to be super smooth it needs to run too rich for my nose and there's a small dead spot around 3800 RPM... For this one time infidelity, I'd like a recommendation for someone that is an MFI-God in SFO, Marin (preferred), Sonoma or East bay, if possible, and will take the time to spend a day on my car with an exhaust analyzer until it's 100% right... Thanks for any recommendations!
    Greg.
    72 911T - 73 2002
    #1461
    Sep 2006
    Eagle, Idaho
    In my opinion you've got two (three if you're willing to travel ) choices:
    1. Since you prefer Marin County, I'd call HI-TEC in San Rafael - excellent Porsche / Audi shop with impeccable reputation and all-around capabilities.
    2. In Concord right on Buchanan Airfield, there's Tom Martenot at DEUTSCHE MOTORSPORT, who is in the process of doing a carburetion / AF ratio analysis on my own car to fine tune the mixture throughout the range, but also knows MFI inside out as well……usues a MO TEC AF analyzer and knows and interprets it masterfully.
    3. JWE, Jerry Woods Enterprises, Campbell, South of San Jose - legendary capabilities and stellar reputation as a Porsche racing specialist , AND has an engine dyno which he uses to great effect…………….not the cheapest, but very good.
    You won't go wrong with any of these shops.
    JZG
    HI TEC is where to go. San Rafael.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Atlanta, GA
    You guys on West Coast a lucky to have so many choices.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Thanks guys... Actually I am a stone's throw (OK maybe slingshot) from Hitec, ScarGO and proshop. I just wasn't sure who among them might be an MFI expert, and I knew Hitec changed ownership - thanks for the perspective...
    Greg.
    72 911T - 73 2002
    #1461
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    Quote Originally Posted by Greg D. View Post
    Did you get your car sorted out yet? I need MFI tuning on my 72 T following a top end overhaul. It runs rough when cold, and has some minor backfiring when hot. Also it occasionally idles at 2k rpms. I don't know how to improve it further, and it has been to 2 (quite expensive) Porsche mechanics on the Peninsula who made it worse, so I undid their work.
    The MFI pump and injectors were overhauled by Pacific, valves adjusted, electronic ignition installed but it is still difficult to get the timing right. I'm beginning to suspect a worn distributor or throttle bodies.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    HiTec sorted it out, mostly. The car runs the sweetest it ever has, without being overly rich (which was the previous bandage).... I want to say from memory that the fuel pump was delivering too much fuel and that the timing had changed for the worse... With the basics reset and the MFI distributor re-tweaked some more, it screams now...
    He did mention that while MFI makes for great race engine - at full throttle, it never was the smoothest of all injections... That said I no longer feel dips in power, it runs sweet - idles a little too high (1100 rpm) but that would require another trip and several hours. I'm enjoying it as is for now...
    I can now breathe with my window down when I stop and my exhaust catches up with me! Before i was suffocating on gas fumes and my eyes were watering like I was peeling onions ;-)
    Greg.
    72 911T - 73 2002
    #1461
    Jun 2014
    Norcal
    On my other 2.8 rsr MFI motor, I used Schatz & Krum in Sacramento to dynotune. GD Racing in San Bruno built the motor and recommended Stu Krum from Schatz to tune it. They had the car for a while but were excellent. My motor was previously too lean on the upper RPMs and too rich on low RPMs and the injection pump had to be removed for Gus to adjust it. After getting the pump back, it was dynotuned and all the black smoke on low rpms were gone. Plus, the gas mileage improved and got 30 more HP! No problem on the idle for that engine and it made over 300HP.
    Apr 2011
    N.Calif., south of SF
    I'm in the middle of this right now. Have sent out the throttle bodies and awaiting their return. They were worn and were allowing air in to the throttle plate shafts. While waiting I had Gus at PFI check the injectors and they spray well and fine.
    I recognize the "too rich at low RPMs, poor gas mileage ... etc" symptoms.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Nov 2003
    Santa Monica CA
    When my idle started climbing on my 2.2S to 1500 to 1700 rpm's,one tech said I had air leaking past the throttle bodies. So that means the stacks need re-doing.(throttle bodies). I took the car to another tech and he said that is one possibility but also it could be just my distributor out of wack. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
