Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: 100 L fuel sender problem.
  1. #11
    Member geracing2000's Avatar
    Mar 2012
    Pescara, Italy
    Hi Guys,
    As already said the 100 liter is about a couple of inches taller than the standard and both of them have 3 thin wires and a floater inside the aluminum tube. If the section of the tube is not round and the wires are in any way damaged, the sender will not give the right reading at the instrument cluster. Repairing it is not easy but possible.
    What i want to say to anybody is looking for 100 liter tank that matches the original porsche specs for this option should also need the correct 100 liter instrument cluster. Have a look to the PET and, for example, for 1968, 90174150207 is the ''80 mm instrument cluster for 100 L fuel tank'', 90174150205 is the ''80 mm intrument cluster for 62 L fuel tank''. I have both and the only difference that i noticed is the PET number on top of the instrument, behind the glass, but for sure there is some internal difference.
    Said that be sure to have at least a tall working sender. Original wiring is fine as it is. Don't mess with it.
  2. #12
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    Has anyone been able to repair the faulty sending units from Marek?
    Does anyone have a working one?
    Mine is not working at all, and it was also very flimsy put together.
    Got it new from marek, stored safely till the project was finished.....
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
  3. #13
    Sep 2009
    UK
    Bumping this thread. Looks like mine is also not working. I will put my original back in at the weekend to confirm or not. Did you guy's get these to work or get a refund from Marek.?
  4. #14
    Jan 2007
    Netherlands
    Dave,
    Marek does not even respond when you try to get in touch about these. I've been fiddeling with it and got it to work for a short while. The issue is with the float-boal that is arou d the center pipe. It does not slide freely because it expands in the fuel. If someone would be able to 3-d print one that floats freely, it can be solved.
    The electronic mechanism in the inner tube, does not seem to be the issue.
    Rgruppe #674
  5. #15
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    i have the FVD 110L ST tank. Same problem with sending unit. Gauge reads empty with low fuel light on.
    Would anybody have an option for me?
    www.tcspeed.com
  6. #16
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    https://specialtycarsservicecenter.com/ look under parts. They make the fuel tank sending units 100 & 110L. .....cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
  7. #17
    Nov 2015
    Quote Originally Posted by Cliff View Post
    thanks for the link!
    www.tcspeed.com
  8. #18
    As stated in post #11, it has also been my experience that the dash gauge itself is different.
  9. #19
    100 Liter Fuel Gauge
    . . . also been my experience that the dash gauge itself is different . . .
    . . . another post . . .
    https://www.early911sregistry.org/fo...l=1#post864517
    Short Version --- pn 90174150203?
    Sep 2009
    UK
    Update: put my original sender back on, works fine. Installed a speciality cars 100 litre sender which also works. That's two lot's of crap i have bought from Marek now. Wonder if he will refund me my £90.00 quid. ? Was that a pig just flew by my window...!
