Hello,
I am sure this is old hat to many of you. I'm interested in learning about early 911 cars with an eye to eventually repairing my 1970 enough so that it might be driven. I am new to porsches but have owned a number of older (mostly much older than this one) autos - (mostly commercial and utility types (4wd, trucks, buses etc) My car is generally poor and suffered from corrosion, neglect, thieves/vandals and a number of poor quality previous owner upgrades and repairs. I purchased it out of a horse pasture where it sat unloved for many years. I have had some "local porsche guys" look at it and most everyone tells me to part it out and put the money towards a better car. I am resisting the temptation to do that and telling myself it is repairable and I will learn more by fixing it.
The Car
-1970 911T targa
The good
-the car was inexpensive
-appears to have a 911/02 "s" motor (also 1970) which turns over and does not have any obvious damage and upgraded chain tensioners - it can probably be made to run.
-has fuch deep 6 heart wheels which appear to be a matched set (all 1970)
-rolls steers stops (brakes do work amazingly) and the car is MOSTLY complete
-911/01 transmission (1970)
The bad
-rust in the rockers (inner and outer), drivers footwell area, bottom of the targa bar where it joins the body and various small flanges and supports
-front torsion bar mounting is soft and the area between the two batteries is previously repaired in a less then ideal manner
-damage to the door and fender where it appears the door was folded back against the body
-the entire car is covered with avery thin layer of bondo (or a very thick layer of paint?)
-seats steering wheel and a few other non original items have been fitted
-wiring is original but various previous owner fixes and so on have made a mess of it
-interior is haggard (but all there)
-poor door gaps/panel alignment
-front bumper trashed
-someone took the center caps for the wheels and the emblem from the hood and tried to unbolt the carbs and steal them but they gave up and left the carbs
-lost title (but Ive don't a DMV vin inspection and seems like this will be straightforward)
-targa top has a crack in the frame and all the material has rotted away
-(this might be the worst)I do not have unlimited amounts of money to pour into this car but I am handy/patient/resourceful
My goals are:
1) to learn about early 911s/network with other owners
2)Make the car run and drive
3) repair the rust
4) make it complete/straight(er)
5) drive it and determine if I like porsches enough to invest in the cosmetic work
6) Id like to spend no more than 5K on this work
Any feedback appreciated on how realistic this endeavor might be from someone who has done this before?
-Cheers
-Ike
