Results 1 to 10 of 11
Thread: undercoating
    undercoating
    Hi,
    my car just came back from dry-ice blasting and now the belly pan etc. is nicely down to bare metal. My question now is, can the undercoating be directly applied to the bare metal or should there be a layer of base/prime coating first then the undercoating and then paint the undercoating?
    Thanks for any help in advance.
    Regards.
    Stefan
    On my 73S resto we put primer before body deadener
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Primer first, then undercoating, during the resto of my 1971 911S.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Very good,
    thank you for your help gentlemen.
    Regards.
    Stefan
    Nov 2010
    Norway
    My 71S is in the paintshop this week, and we put epoxy primer on bare metal all over the car.
    I will post some pictures here before xmas.
    ST
    Jul 2006
    Corvallis, OR
    Epoxy primer for sure and then undercoat.
    72S, 72T now ST
    Nov 2015
    Arizona
    So what are you guys using to replicate the 69-73 PVC style undercoating? All the products I have researched are too thin after application. The factory PVC undercoating is very thick. And what is the original color of that undercoating? I know it is hard to tell on a 45 year old car. And I am color blind which makes it even more difficult. I am thinking mostly Beige with a bit of Gray.
    Oct 2010
    Southern Ca.
    Porsche used two colors , a tan and a grey . Also for trivia , 69S's built by Porsche did not use the PVC style undercoating , still used the 356 style .The Wurth SKS
    replicates the original undercoating very well , but you must use their spray gun .
    Junior Member
    Sep 2013
    Northern California
    Correct undercoating surfaces for '67 911S?
    Does anyone know the correct areas to undercoat on a '67 911S? Is it the engine bay or engine bay & entire floor pan? We will use a water base smooth finish product for durability which is not spec but would like to apply it on the correct surfaces.
    Thanks for your advice.
    Matt
    Jul 2008
    South Florida
    Quote Originally Posted by dusty911fun View Post
    Matt
    The search function is your friend. Nearly EVERY question regarding restoration details is somewhere on this forum.
    http://www.early911sregistry.org/for...7+undercoating
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
