Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 81
Thread: We're Saved! Repro Hood Strut Decals
  1. #21
    Nov 2006
    S. F. Bay Area
    Al well and good, but does anyone make the struts with the chrome (not black) rods?
    Brian
    S Reg #1032
  2. #22
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    Ok--if you folks had your druthers, would you want the bottom line to be printed or would you want that blank so you could ink stamp, if you're of the mind to?
    I see that as three options:
    a) blank (have your fun)
    b) printed except for last little bit where you could ink stamp in 01/68 or whatever. (our original thought)
    c) printed with a date (a broken clock in this case is only correct once.)
    Per Schroeder
  3. #23
    Mar 2013
    Avon Lake, Ohio
    Anyone? Bueller? Or would that be Buetler?
    Per Schroeder
  4. #24
    Nov 2006
    S. F. Bay Area
    I'm for option (b).
    Brian
    S Reg #1032
  5. #25
    Mar 2013
    Avon Lake, Ohio
    Thank you! We could probably "age" the last line a little bit so it looks a little more like an ink stamp.
    Per Schroeder
  6. #26
    Quote Originally Posted by Per Schroeder View Post
    Like this?:
  7. #27
    Mar 2013
    Avon Lake, Ohio
    Yes, Manuel! Thanks for your help in sorting this out.
    Per
    Per Schroeder
  8. #28
    Question is when were these stickers on the struts. If only 68 and later, then c is preferable. As has been pointed out before, Porsche took whatever was on shelf. How would date even be relevant as to when owner purchased a replacement? Looks better if pre printed.
  9. #29
    Sep 2013
    Vancouver, WA
    They were obviously prior to '72 as I have still have my original Stabilus Koblenz hood shocks on my car. Those were printed directly onto the strut. The original post says '65 to '68.
  10. #30
    We are close to having these done. Biggest issue is the date code which means we would likely go with option B. Material, fonts and text will be correct unlike the Stoddard version. Seems that ever since they came under new management quality control has been lacking.
Tags for this Thread
