Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 144
Thread: 300096
  1. #131
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by softwindow View Post
    This seems to be a reproduction of the 64-key pouch.
    https://www.ebay.de/itm/Original-POR...0AAOSw5nJc9ptm
    Bernd
    Funny, those key fobs are 15,70 € cheaper at Erlkönig Classic's website. It's unlikely these particular key fobs with Karosserie Reutter stamped on one side would have been given out after Porsche bought the Reutter factory in 1963.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  2. #132
    Quote Originally Posted by NeunElf View Post
    These fobs also came with other body builder stamps or only with the Porsche crest. As such they were not reutter specific
  3. #133
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Moito, Franz,
    did #96 come with a lockable steering wheel, thus the FL type key,
    or the non lockable ignition switch, thus the K type key?
    key issue also discussed here:
    http://www.early911sregistry.org/for...g-car-key-case
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  4. #134
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by haul View Post
    Moito, Franz,
    HI Haul
    as discussed via phone today ..yes cardex shows FL key ...im not aware that any 64 came with non lockable ignition switch but i will go through my recordings when i find the time.
    attached a few pix of the fobs ...all came from the same german manufacturer and out of the same old box ..note the horse with eye and much slimmer shape ...and the plain back
    cu
    an other question for today
    what would be the correct HL reflector for `64
    i do have several versions and i think #2 (non city light with cap) would be the correct one...any thoughts?
  5. #135
    Franz, non city i believe, the ones with the city provision are VW
  6. #136
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 718RSK View Post
    non city with cap--right?
    will pm you in a short
  7. #137
    Jul 2014
    bavaria
    @franz
    could you please do me the favour and post the measurements of the T bolt from the high rise grill, please?
    thank you...
    br
    haul
    erwin_loves_polo
  8. #138
    May 2013
    AUSTRIA (tu felix)
    Nice Franz, did yours have the din 125 zinc plated washers under the cap nuts also? 11x5x0.6 from the top of my head. Din spec on those has since changed
    nope the stainless steel are 8x4,3x0,4
    the aluminum used on later versions of the grille are 8,7x4,5x0,55
  9. #139
    May 2013
    AUSTRIA (tu felix)
    @franz
    thank you...
    br
    haul
  10. #140
    Jul 2014
    bavaria
    Dear Franz,
    thank you..
    erwin_loves_polo
