1100/2241
1448/2387Henk
after i inspected the car at gelderland (pre purchase) i recomended NOT to buy this car for the reasons you mentioned
and yes we are aware of the engine issue.
maybe i should have a closer look at my rotten fuel tanks...never reuse the strainers ...
yep--thanks for offering your help.
cu
franz
59 750 pre unit triton
65 912 slate gray "erwin"
73 914 ravennagreen "ferdl"
erwin_loves_polo
time for a short update...
i sourced almost all parts missing or incorrect.
deck lid grill,steering damper,hood chrest,64 steering rack,headlights,correct nuts and bolts,etc..
the only hard to find parts are the grey vac formed drip pan...the one i sold just a few days before i got this project..
http://www.early911sregistry.org/for...648#post826648
and the early pre production interior mirror
so if you have some of this stuff for sale let me know.
status of the restoration is that i still have not decided if i go for acid dip and cataphoretic painting
or striping paint by water jet
https://www.youtube.com/watch?v=rKLsUCWRjaQ
floor pan is almost finished(also on the inside) only need to know the number position of the metal straps that hold the brake lines.
front fenders(like new 68 ones) are mostly converted to 64
door corpuses also.
http://www.early911sregistry.org/for...246#post881246
so far all metal pices i welded in are original parts...and there are plenty of those if you convert a g-mod rhd floor pan
still looking for the correct front slam panel or section of it.
progress is slow but i want to get it all done correct
3334/3478
This is a good one to watch. Franz's metal work is excellent.
Just so you know - Restoration Design is making a new "front lip" panel, the part that holds the front bumper to body seal against the nose panel. This new part will be the 65-early73 type with no drain holes. I have been helping them with details from my original cars so it comes out correct. I don't think it is done yet but very soon.
Over the last few years I have finally convinced them to remake their rocker panel molds so we can finally get good replacement rocker panels with correct drain holes rather than the bad Dansk type shape. Took forever to find a NOS green rocker panel to scan but I finally did late last year. This is still in the works but I will post more info when I get the first rockers out of the press.
So there are 3 pieces that will not need to fabricated.
The sand blast w water video is interesting, called Dustless blasting here. But this dry ice video is really amazing.
https://youtu.be/uJ8hEp0ohsI
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
Mark Erbesfield
1957 356A #58648
There's a guy here in San Diego doing that now...
1965 911 #301111, Red Book Vol 1 "Cover Car," owned 53 years.
1967 911 #307347, bare-bones, some road wear, a little surface rust, and a few dents..., owned 13 years.
Registry #983
R Gruppe #741
and a few pics of the fender conversion and pedal cluster repair(someone messed up the bolts)
