Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 144
Thread: 300096
  1. #61
    Gas Drain tube
    Referencing back to post 41.
    This was car 300 149,
    December 1964 build.
    Bob
    Early S Reg #370
  2. #62
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Bobs 67S View Post
    Bob,thank you very much for posting this pics and your earlier input about the seats.
    DANKE
    franz
  3. #63
    May 2013
    AUSTRIA (tu felix)
    am i seeing a spring-ring here?similar to the one pictured...
    or is the tube just disconnected
    4293/8440
  4. #64
    Drain tray under Cowl
    The original drain tray was a vacuum formed black plastic piece , about the thickness of the under piece of the interior door handle.
    With the center metal holding bracket pressing up and a high heat gain area the black plastic piece split (front to back of the car) right at the edge of the holding bracket.
    Water damage to the trunk interior resulted in some wet carpet and rust along the gas heater door and forward.
    (Almost centered in the driveway parts photo.)
    This replacement drain tray was 901 571 231 23, in place by car 950, and more than likely, much earlier.
    Does anyone know when this was replaced with the fiberglass tray? (last two digits changed to 24 )
    Bob
    Early S Reg #370
  5. #65
    May 2013
    AUSTRIA (tu felix)
    1085 still had the grey tray...i was always wondering why they changed to the for sure much more expensive fiber glass type..now i know
  6. #66
    Reply to post #63 Gas Drain hose attachment
    Yup. That is a ring.
    It was still attached. (One of the few items that I never had to take apart...)
    Boy you have a good eye.. the more we look - the more we see...
    Bob
    Early S Reg #370
  7. #67
    May 2013
    AUSTRIA (tu felix)
    Yup.
    yup it`s a ring ?
    or
    yup it`s disconnected?
  8. #68
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I have record of 1115 still having the grey tray, a car once sold by BHCC. John's 1111 also has it. Thereafter only fiberglass in my records. Assume changed early May
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  9. #69
    May 2014
    Netherlands
    By the way, where to get the rubber seal on the edge of the tray? the soft rubber always needs replacement. Who supplies this?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  10. #70
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by pss View Post
    have a local rubber wholesale here in SBG that suplies me with this... not 100% correct though.
