Results 1 to 9 of 9
Thread: Had to share
    Banned
    Nov 2004
    Scottsdale, AZ
    Had to share
    A couple of days ago we actually pulled this off an '05 997 that has a supercharger on it.
    Yes, that's a toilet shut off valve.
    Mar 2006
    Louisville KY
    Makes sense the car is water cooled.
    Tony Proasi
    52 split window coupe
    Frank,
    Gotta love your competition-
    Phil
    Early S Junkie # 658
    yes, that's a toilet shut off valve.
    perfect...........
    Senior Member 767driver's Avatar
    Oct 2008
    Parkton, MD
    Quote Originally Posted by 911quest View Post
    Now that is funny!!!!!!
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Restoration newbie.
    Jun 2007
    San Francisco
    Here's mine:
    That's a 901 throw out bearing guide tube with... a coke can used to create a new running surface on the tube. I have no idea how this didn't self destruct. The car has been off the road since '85 so that has helped. Probably a good thing too since the simplified diff was still simple and the stretch bolts didn't have a hell of a lot of life in the end nipples.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by ajwans View Post
    Here's mine:
    andy
    My first thought is "why"? Even a ton-o-slop between bearing and sleeve won't cause binding on a 901. I suspect someone was chasing a diaphragm or cable problem.
    I'm guessing an engineer/owner was involved.
    That says alot about the rest of the supercharger install.
    Restoration newbie.
    Jun 2007
    San Francisco
    The guide tube had a groove worn in it which was probably hang ing up the bearing
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
