Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Luggage compartment light...
    Feb 2016
    Kirkland, WA
    Should there be a light in the hood of a '67 911S SWT as standard? Or an option? Or never anything?! Thanks.
    Two lights I believe, standard on the S.
    Feb 2016
    Kirkland, WA
    I mean under the hood.... not in the interior of the car. Thanks. Greg
    Oct 2010
    Stockholm/Sweden
    One on each side on 911, only one on 912s.
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Until 73 when it becomes 1 light only
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Sep 2013
    Vancouver, WA
    So this means that '73 hoods are different than '72 hoods?
    Yes sir that is correct
    Pic from RS 101 Nov 72 build
    Clyde Boyer
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by BOYER73S View Post
    My 72 only has one light, like in your picture. Build date 5/72 as per the tag in the door jam. So it is wrong?
    Paul Harrop 12.5% German.
    Early S #2059
    Aug 2011
    north of the 49th parallel On Can.
    if your hood has two openings for lights put two in cheaper cause if it came from the factory with only the one light the other opening had a color matching cardboard with 2 white plastic rivets holding it on. You would be very hard press to find then, as I've only seen two covers up for sale in the last 10 years not that I'm looking for one.
    Hope this helps
    hopper
    Quote Originally Posted by dummkopf View Post
    Maybe not I thought the change was 73 model but your car is very late 72 so anything is possible from back in the day
    Others will hopefully chime in to confirm or correct my statement.
    Clyde Boyer
