Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Luggage compartment light...
  1. #21
    Feb 2016
    Kirkland, WA
    Can you upload a photo to what it looks like where the switch 'hit's the body to turn the light off? Also, can anyone show where the original wires 'came from' under the rear of the dash (I assume?). Thanks!
    Quote Originally Posted by WHCJr72S View Post
    My January 1972S, which I purchased in April 1979, did not have a trunk light! It must have been made on a Friday. The hood has punched hole on the passenger side for the light (which it now has) and on the drivers side there is an embossed but not punched area for the other light.
    Gearby the light switch is located near the passenger side light. It is in the center of the hood hinge on the opposite side of the light. My car does not have original wiring for the light. I am looking for the original wire in very good condition.
  2. #22
    Senior Member WHCJr72S's Avatar
    Bay Area
    The trunk light switch pushes on the metal arm to turn it off. The switch is the same switch as used on the door lights (901.615.601.01). It provides a ground for the light when the door or hood is opened.Name:  DSC09350 trunk light & switch.jpg
    Bill Cilker, Jr.
    Gold 72 911S
    31 Ford Model A
    PCA, Early S Registry (#98) & RGruppe (#272)
    Rotarian
  3. #23
    Feb 2016
    Kirkland, WA
    Thanks Bill... my car has that little arm out the side but it's covered by the trunk lining. Anyone out there that can snap a photo of their original setup for the light? I'm thinking mine never had one...
  4. #24
    Bay Area
    Here is a picture of mine with the carpet in place. The carpet used to cover the arm. The clip and the routing of the wire I believe are correct.
    Bill Cilker, Jr.
    Gold 72 911S
    31 Ford Model A
    Rotarian
