Page 37 of 72 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 711
Thread: 911S Resurrection Not Restoration
  1. #361
Size:  92.6 KBName:  IMG_20190707_155650.jpg
Size:  77.9 KBName:  IMG_20190707_155656.jpg
    Do not lift the car much more apart from that image that you see. I had to dismantle the fan and when I pulled it out, it helped my brother to tilt the engine a little. I like this more, than lift the car
  2. #362
    Quote Originally Posted by platas View Post
    There where several of these cars brought to the Canary Islands. The Canary Islands, where like a free port, plus one of the most favorites pplaces for the germans to retire.
    Once retired, they brought there cars to the Islands, and with time many past away or went back home.
    I know that he has tried to get more info on the car, like the other post says, but IMO its just a good S that was turned into a rally car the old fashino way, before, many recreations parts where available.
    Also this restoration, i do agree with Oliver, its not for the DIY, but a Porsche specialist, problem is that if done corectly , its extremely expensive, this said, theres only 1 o 2 persons who can do this kind of work in th Island.
    To send the car to mainland , is complicated, even though the Canarys, are part of Spain, but they have a special status, and theres certain burocracy to the whole import and export from there.
    RS Targa is correct, i had this same problem with MW ST, he MW tried to repair the plastic, 100 L tank, i also tried to reapir it, and where still getting a gasoline odor, so eentually, the tank will be exchanged for a metal tank 100 L.
    I hope he keeps post coming.
    Do you have any news about your opinion?
    Saludos!
  3. #363
    It has been a boring, delicate, boring, delicate, boring, delicate work .... The frame of the window was worked with a lot of patience so as not to weaken or dig more than necessary!
    http://soloporsche.com/xf/index.php?....86250/page-59
    User darpedie its me.
Size:  51.3 KBName:  67356141_2282407265356665_4452408603659206656_n (1).jpg
Size:  90.7 KBName:  67470996_365472344166678_5632742913126432768_n.jpg
Size:  71.3 KBName:  67556906_458961397996414_2194705503454494720_n.jpg
Size:  67.4 KBName:  67505585_2283305871786001_4243518995157745664_n.jpg
Size:  56.4 KBName:  67087246_615297912331510_3565407512398135296_n.jpg
Size:  48.0 KBName:  67402679_606025183256434_1682379809860091904_n.jpg
Size:  24.6 KBName:  2222.jpg
  4. #364
Size:  48.9 KBName:  ddd.jpg
Size:  29.2 KB Name:  video.jpg
Size:  17.6 KBName:  66843671_484813022114891_1629810728712011776_n.jpg
Size:  36.1 KBName:  67104395_868648603503636_3455534354816565248_n.jpg
    upload a video of the process
  5. #365
    The vin 9112300495 delivered in April?
    My car 9112300576 came out in January.
    Is it normal for a newer chassis to be delivered before an older one?
    Which of them matches the registration of all other VIN 911s?
  6. #366
    Where can I get the reference of what is each wire and color? I see two wires cut
Size:  86.7 KB Name:  IMG_20190811_124930.jpg
Size:  76.3 KBName:  IMG_20190811_125240.jpg
Size:  102.1 KB front harness, right headlight
  7. #367
  8. #368
    The fins were welded to the body with gold for repair and I think I suppose the reason?
    If the car overturned, I guess the pillar would have remained weak?
    Therefore ... Were the fins welded to the body to reinforce the pillars of the front ? I say this because on the driver's side there is gold in the front frame attached to the gold of the fin weld. I understand that this pillar, that of the driver suffered enough damage in the rollover and hence this type of repair.
    Therefore I know that all the golden points I have found are repairing BUT .....
    The battery boxes painted by brush?
  9. #369
    Is gray another kind of putty other than pink?
  10. #370
    Sadly, yes...
