Page 36 of 72 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 711
Thread: 911S Resurrection Not Restoration
  1. #351
Size:  69.7 KBName:  IMG_20190412_195246.jpg
Size:  100.3 KBName:  IMG_20190407_204342.jpg
Size:  97.9 KBName:  IMG_20190407_211110.jpg
    I do not know if these photos were already uploaded.
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
  2. #352
    the prototype of 914 had the fins welded to the body ...?Some information about this car
    http://www.early911sregistry.org/forums/attachment.php?attachmentid=189506&stc=1&d=1310924 454
    http://www.early911sregistry.org/for...tion-car/page6
    What can the number 44 mean at the door of my car?
  3. #353
    Can anyone tell me if this piece belongs to the equipment of the S or belongs to the donor engine of the SC that my father bought?
    I have also found several loose cables ...
Size:  132.8 KBName:  IMG_20190702_190714.jpg
Size:  138.0 KBName:  IMG_20190702_190755 (1).jpg
Size:  146.0 KBName:  IMG_20190702_190705.jpg
  4. #354
    Any advice to lower the engine and leave the transmission inside?
    I understand that I can follow the descent procedure without having removed the upper screws of the motor / trans mount? and that halfway through I could finish removing them?
  5. #355
Size:  62.7 KBI have been able to dismantle everything, now IName:  IMG_20190706_225307.jpg
Size:  51.7 KBName:  IMG_20190706_195901.jpg
    just need to remove it from the drawer.Motor break: The part that connects to the selector rod. From the engine in the clutch area ... you move that area and it sounds a metallic noise apart from being able to move it a couple of mm ...What can be?
  6. #356
    Any idea of ​​the breakdown?
Size:  54.6 KBName:  66150957_668881473524338_5958196112975200256_n.jpg
Size:  82.9 KBName:  66384217_2034008453369713_2549036710486867968_n.jpg
Size:  69.5 KBName:  66438973_428555677730938_3323513403804221440_n.jpg
  7. #357
    dismount clutch disc ... to see what I find?
  8. #358
    I have disassembled the clutch disc, but I find that I do not have the tool to remove the bolts from the head to get to the crankshaft ... I read on pelicanparts that I do not try another tool and I will not. Any store or idea that can be used? Online store to buy the head?
Size:  66.6 KBName:  IMG_20190709_003759_025.jpg
  9. #359
Size:  83.9 KBName:  66283806_916233225430384_1310061644864290816_n.jpg
Size:  88.4 KBName:  66671105_709289806195208_1712578871674535936_n.jpg
Size:  73.6 KBName:  66476311_318890115661676_8311929291734515712_n.jpg
    I found some rust, last photo. Something to worry about? Something to keep in mind about the bomb?
  10. #360
