Page 22 of 72 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 711
Thread: 911S Resurrection Not Restoration
  1. #211
  2. #212
    Any picture of any similar number?
  3. #213
    Had left the floor pending, to finish small details ... I remember the phrase that commented a colleague here ... Little by little, and I'm going day by day polishing details ...
    I've also disposed of a side that I had given epoxy to see how it was. I look good, but I have changed my mind and the white epoxy is not a base that I liked a lot for the interior ... I leave you some photos. I've been using scouring pads and a sponge sandpaper with some quitagrasa and "heat gun"
Size:  85.9 KBName:  suelos1.jpg
Size:  128.6 KBName:  suelosbaja4.jpg
Size:  69.3 KBName:  suelosbaja10.jpg
Size:  90.5 KBName:  suelosbaja15.jpg
Size:  103.9 KBAttachment 424290Name:  DSC_0402.jpg
Size:  90.7 KBName:  DSC_0403.jpg
Size:  77.0 KBName:  DSC_0411.jpg
  4. #214
    I have a doubt. Some time ago I asked a question about a hole that had the bonnet, small and perfect. I had forgotten about that subject but my father reviewed it again, seeing that small hole, coincides with a larger hole in the bonnet support, to finally get a hole in the front plate. The funny thing about all this is that one of the holes (if I remember correctly, the one of the bonnet) is of entrance, and the one of the exit plate. The support is a hole totally different from the small holes found but in the same place.
    I do not know what object could have crossed the capo. Some sheet metal instrument?Name:  DSC_0546.jpg
Size:  74.9 KBName:  DSC_0549.jpg
Size:  74.4 KBName:  DSC_0550.jpg
Size:  20.8 KBName:  DSC_1476.jpg
Size:  64.1 KBName:  WP_20160430_13_27_08_Raw.jpg
  5. #215
Size:  48.7 KBName:  DSC_0069.jpg
Size:  72.2 KBName:  DSC_0070.jpg
    These photos are quite old. Surely if you noticed you saw the errors I commented at the beginning of the post. Errors of the photoshop provoked when I still did not have much idea of ​​it!
Size:  155.0 KBName:  7070720223_476aa82126_o.jpg
Size:  50.8 KBName:  7070729685_1c80dce384_o.jpg
Size:  74.1 KBName:  7070734111_d018337d59_o.jpg
Size:  164.0 KBName:  7070753101_7666c400a0_o.jpg
  6. #216
    Hello everyone! I have not been writing for some time now as it has been a rest season here. Returning to work today I have encouraged to remove the set of pedals ... I have it loose although I only need a cable, the brake! Anyone know how to remove this cable?
    On the other hand ... I have been washing the front bumper and I have found a possible repair of the fiber on the right side? Or is it simply fiber of another color? !!
    Saluds!!
    Name:  WhatsApp Image 2017-07-13 at 21.04.04(1).jpg
Size:  92.5 KBName:  WhatsApp Image 2017-07-13 at 21.04.04.jpg
Size:  108.6 KBName:  WhatsApp Image 2017-07-13 at 21.04.06.jpg
Size:  96.9 KBName:  fibrabaja2.jpg
  7. #217
    Hello, today after yesterday I spent enough time with the cable. Come to pelican! Solve it with the "manual" number 9 ... How simple things are if you have the correct instructions. The area was ugly at first but I have been removing material and it is healthier than I thought. I dedicated the afternoon to sand and prepare the handbrake ... The day on the terrace and the sandpaper in the hand "A cundido"
    Name:  WhatsApp Image 2017-07-14 at 18.34.14.jpg
Size:  61.0 KBName:  WhatsApp Image 2017-07-14 at 21.06.16.jpg
Size:  55.3 KBName:  WhatsApp Image 2017-07-14 at 21.06.17(1).jpg
Size:  64.8 KBName:  WhatsApp Image 2017-07-14 at 21.06.24.jpg
Size:  72.3 KBName:  WhatsApp Image 2017-07-14 at 21.06.32.jpg
Size:  69.8 KBName:  WhatsApp Image 2017-07-14 at 21.06.35.jpg
Size:  114.9 KBName:  WhatsApp Image 2017-07-14 at 21.06.40(1).jpg
Size:  85.5 KBName:  WhatsApp Image 2017-07-14 at 21.06.41(1).jpg
Size:  92.4 KBName:  WhatsApp Image 2017-07-14 at 21.06.44.jpg
Size:  58.3 KBName:  WhatsApp Image 2017-07-14 at 21.06.17(1).jpg
    Name:  WhatsApp Image 2017-07-14 at 21.06.51.jpg
  8. #218
Size:  59.6 KBName:  DSC_0081.jpg
Size:  53.0 KBName:  DSC_0094.jpg
Size:  76.4 KBName:  DSC_0096.jpg
    I see number 2 a little distant from the rest. Is it normal?
    From what they tell me, it's normal. Anyone want to add alignment information? Does 2 have to be aligned with the asterisk?
  9. #219
Size:  44.6 KBName:  DSC_0101.jpg
Size:  58.2 KBName:  DSC_0103.jpg
Size:  60.9 KBName:  DSC_0104.jpg
Size:  65.9 KBName:  DSC_0107.jpg
Size:  59.0 KBName:  DSC_0113.jpg
Size:  80.1 KBName:  DSC_0112.jpg
    What kind of grease do you use to grease the gearshift?
    The inner area has not been sanded. I have removed the old fat, pending replacement!
  10. #220
    Any ideas on how I could serve these holes in the front spoiler? There are 3
