Page 39 of 72 FirstFirst ... 29373839404149 ... LastLast
Results 381 to 390 of 711
Thread: 911S Resurrection Not Restoration
  1. #381
    thanks for your answer! Any more to corroborate? I can't find the color scheme for the back and the one I have doesn't match
    the cable length is 1.18 cm approx.
  2. #382
    Rear
Size:  39.6 KBName:  IMG_20191022_210109.jpg
Size:  59.5 KBName:  IMG_20191021_215016.jpg
Size:  60.4 KBName:  IMG_20191021_215004.jpg
Size:  61.8 KBName:  IMG_20191021_215358.jpg
    GREEN-WHITE/GRAY
Size:  57.9 KBName:  IMG_20191022_205919.jpg
Size:  66.3 KBName:  IMG_20191022_205945.jpg
  3. #383
  4. #384
    Oct 2010
    South Carolina
    Oh the horror!
  5. #385
    Quote Originally Posted by bfunke View Post
    Oh the horror!
    ?Thank you for expressing your opinion with its high information content.It is to be thankful.
    XD
  6. #386
    In case it has not been written, I think clearly, that the pink bondo does not belong to the preparation of the car, but to a repair. You can see pink putty on top of yellow in pieces st. Someone who had done this preparation would have been more careful. I've also found the "heat suckers" in the hood. To practice the opening, heat was given to bend.Name:  IMG_20191024_125956.jpg
  7. #387
Size:  43.2 KBName:  negra.jpg
    I have taken this photo to illustrate the black line that I find in my car. I do not know if you ever comment ... But the car has a black line in the strip, I would say the same thickness as the image. What was that black line for? I see that it is black paint (not rough, rather, smooth) is under all the paint. This I have observed on the driver's side.Name:  73236059_629631037566502_3000429531254226944_n.jpg
Size:  81.8 KBName:  75289386_784485291972979_3324023246487027712_n.jpg
Size:  70.2 KBName:  72692198_712502732566662_7007295858467143680_n.jpg
  8. #388
Size:  69.1 KBName:  IMG_20191028_110631.jpg
Size:  81.0 KBName:  72798512_2465742656815056_8729511481407700992_n.jpg
Size:  86.0 KBName:  73515720_820139068441172_6628586468602281984_n.jpg
Size:  124.0 KBName:  72874989_757170894725594_8867605391622537216_n.jpg
Size:  65.1 KBName:  IMG_20191028_184256.jpg
Size:  140.7 KBName:  IMG_20191028_184309.jpg
Size:  149.1 KBName:  IMG_20191028_184315.jpg
Size:  130.1 KBName:  IMG_20191028_184322.jpg
Size:  113.3 KBName:  IMG_20191028_190549.jpg
  9. #389
Size:  70.2 KBName:  IMG_20191028_191907.jpg
Size:  58.3 KBName:  IMG_20191028_194517_401.jpg
    I hope you can "enjoy" these photos as much as I do, seeing the work done.
    I also hope that the way in which the bumper was prepared is clear.
    Salds to all!
  10. #390
    What did you do with these pieces when you built them ... I filled the solder tin with tin to give it a more correct shape or is it supposed that being in metal should already have the right shape? I haven't found tin lead in the bumper and I see that the shape (despite the bumps) is good. How do I continue? Print? Tin lead? Any similar restoration photo ?
    How much should a bumper weigh?
