Thread: WTB: Left Euro Turn signal housing
    Jan 2006
    Naperville, IL
    I am looking for a left hand side front European turn signal housing; My current LH housing is in poor condition and I prefer a more restorable housing.
    To be clear I am looking for a used part to restore, plastic housings NOT considered only metal. Please PM or email.
    Thank you,
    Andrew
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    The Netherlands
    LHS LWB turn signal housing
    Hi Andrew,
    Unfortunaltely I do not have the Euro version with the divider already mounted in the housing, just these two left US housings. Not difficult to take the Zinc divider out of the Euro housing plus the white single wire and mount it in this housing. Top housing had a small hole in one of the corners as seen in the pictures. Housing might need some refecting paint but they are both solid. Asking $110,- for the top one, $125,- for the lower one.
    BR,
    Cees
    Jan 2006
    Naperville, IL
    Cees,
    Thank you for posting; I would prefer to find the euro housing as my current divider was altered and the small plastic reflector is missing. If I am unable to find that, one of your housings will certainly be the next candidate. ;-)
    Thanks again,
    -Andrew
    -Andrew
    '72 911E
    S Reg #1074
    The Netherlands
    No worries Andrew, I will check the German eBay as well, they are out there but not many!
    Cheers,
    Cees
    Jan 2006
    Naperville, IL
    Still hoping to find a good Left Euro housing with small plastic reflector and divider.
    My current housing just a bit worse for wear...
    Thanks all
    -Andrew
    '72 911E
    S Reg #1074
