Thread: Holes in a 1965 headlamp bucket
    This is the headlamp bucket of a 1965 car still with the matching VIN number stamped into it. It has 4 tiny holes with a small white plastic insert, arranged as a square, 2 on the left, two on the right. Haven't seen this before. If this is original what is it for then?
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    are those holes at the same position where later bowls had the tabs for the US headlights?
    Yes Franz.
    May 2013
    AUSTRIA (tu felix)
    since today i`m not sure anymore when the tabs were introduced.. but i m sure the holes are for positioning them.
