Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: source needed - RSR muffler
    Sep 2008
    Auckland , New Zealand
    after a RSR muffler like this to get my car on the road , bolt on to std headers . Patrick motorsport only do ups del at the wayyyyyy over the top cost , who else has them
    http://www.patrickmotorsports.com/pa...sr-wide-style/
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    You can buy an R Muffler from Dansk. As for fitting it up to stock headers, you'll have to fabricate that part like Patrick would.
    Armando Serrano http://www.pbase.com/9146gt has done this conversion using Dansk muffler for his 914/6 GT but that one is still utilizing the megaphone style extensions off of headers and clamped to the back just like the "days of old".
    Good luck.
    Early S Registry #235
    rgruppe #111
    Or you could make your own as I did. You do need to cut out the baffles inside. I used 2 1/2" tubing for the pipes, they need to be large to look like the 'R'.
    There you go! Have Ed build it.
    PS:
    Ed: What are you using on the back of the glass bumper for heat control? I've seen a few white ones that are now brownish.
    rgruppe #111
    Aug 2006
    Chicago area
    Ed, can you share your procedure for cutting out the baffles? I have a muffler I would like to do this to. Thanks.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Sep 2008
    just doing that now to a muffler i started , we will see how it goes
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Quote Originally Posted by t6dpilot View Post
    Pretty sure Ed did it this way per Upfixin' Der Porsche.
    rgruppe #111
    The centers were already cut out as I started with an old sport muffler done as per that diagram. but for the outlets at the very ends of the muffler also involved cutting holes in the end baffles in the same fashion,,,ie. thru the holes you'll cut for the pipe outlets.
    May 2005
    Southern California
    We did the opposite, re-manufactured an R to a GT Rally Muffler. You can see part of the metal-surgery in the photos posted below, and the rest can be found here
    Back in 2006, there were NO "914-6 GT" Rally mufflers available, OEM, or Reproductions. That said, there was an "R" / "RSR" type Rally Muffler available and I took advantage of it.
    At the time, the natural thing for me to do was to convert the R repro muffler to a GT and this is now history. To my recollection, we were the first to actually make this GT muffler conversion. A few years later the GT reproduction mufflers appeared.
    Take a look...
    Both exhaust tubes were removed, leaving their respective large holes.
    Holes covered...
    and perfectly finished.
    This next photo shows the relocation of the exhaust pipes, moved in closer, a la 914-6 GT.
    Side-by-side comparison of an OEM and the new repro GT muffler.
    Owning an original 914-6 GT muffler (at bottom of pix) sure made the conversion a bit easier.
    Extremely happy with the results.
    Cost effective? Heck NO! It was probably the most expensive 914-6 GT reproduction muffler ever produced. Not doing that again!
    May 2005
    Southern California
    My suggestion? Buy this GT Muffler and reverse my process.
    The 914-6 GT repro mufflers are very inexpensive these days, Euro 651? Wow!!!
    I believe paying around $2,500 back in 2006, just for the R repro muffler we transformed, that was my price of admission.
    Finding the skill-set required to do the same, that may pose a bit of a challenge, and it won't be cheap.
