Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: FS: 67 Porsche 911 deluxe RS Certificate of Authenticity KARDEX $250,000.00
  1. #21
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Bill Simmeth View Post
    I'm amazed that the owner didn't accept the $225K bid...
    Truly... this may be a shark jumper when people look back on the cooling market for early 911s.
    Someone actually bid this car up that high and the seller couldn't let it go. geez
    1969 S Coupe #761
    Early S Registry #1624
  2. #22
    Apr 2005
    Oregon
    Probably was shill bid to that price.
  3. #23
    FS: @MECUM Auctions Monterey - 1967 911 'Deluxe RS' Coupe
    Still looking for a home . . .
    Other threads/posts on this car:
    http://www.early911sregistry.org/for...ghlight=304769
    http://www.early911sregistry.org/for...l=1#post882335
    MECUM 2017 Monterey Auction, Hyatt Regency Monterey Hotel and Spa - Del Monte Golf Course, August 16-19, 2017
    1967 Porsche 2.0L 911 "Deluxe RS' Coupe, Lot S96
    VIN: 304769
    Engine: 907962
    Trans: 231576 (902/1)
    Color: Light Ivory/Black Leatherette Peptia Inserts
    Mileage: ~72,000km (indicated)
    Auction Estimate: US$ -
    Sold for: NO SALE (Highest bid: US$170,000)
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
  4. #24
    Junior Member
    Jul 2017
    Quote Originally Posted by beh91e1 View Post
    Wow that's a beautiful car and I was considering it until I saw it was 250k lol. If only I had the money.
  5. #25
    3rd try? or 4th?? It will not get anywhere close to that estimate. The write up is ehm.... bogus
    ~J~
    air cooled only
  6. #26
    Senior Member Fubawu's Avatar
    May 2013
    when a dealer installed a sunroof do they include the drain hole exits by the engine bay?
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #27
    Junior Member
    Oct 2018
    Quote Originally Posted by Baumgartner View Post
    Wow that's a beautiful car and how to get rid of gyno I was considering it until I saw it was 250k lol. If only I had the money.
    It IS a beauty, but I don't think it is that amount. I wouldn't pay 250k for it even if I had that kind of money.
  8. #28
    "Nearly 200 horsepower" lol, doubtful. That's what I call rounding for sure.
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
  9. #29
    A perfect example of too much exposure with a controversial history and an over ambitious auction estimate.
    MECUM Auctions Monterey, August 23-25, 2018
    1967 2.0L Porsche 911 "Deluxe RS' Coupe
    VIN: 304769
    Engine: 907962
    Mileage: 72,220km (indicated)
    Auction Estimate: US$200,000 - $225,000
    Sold for: NO SALE (Highest bid: US$130,000 - "The BID Goes On . . . ")
    Auction Description:
    - Serial no. 304769
    - Matching numbers engine no. 907962
    - One of 253 original 911 Deluxe RS models
    - European configuration
    - 72,000 kilometers
    - New bearings, piston rings and seals
    - Rebuilt carburetors
    - Reconditioned transmission
    - 911S ratio transaxle gears
    - Light Ivory exterior
    - Kunstil Schwartz Pepita interior
    - Original interior except for new headliner
    - Wood dash
    - Webasto heater
    - Sunroof
    - Detailed underbody
    - Copy of Kardex
    - Porsche Certificate of Authenticity
    - STUTTGART INSPECTED COMMUNITY windshield sticker
    - Estimated $175,000 invested
    - Tool kit
    Beginning in June 1966, Porsche began to develop the exclusive 911 Deluxe RS examples that are rarely known of today, even by the most knowledgeable marque enthusiasts. Porsche utilized 253 previously completed wood-dash, Webasto-heater cars—chassis numbers 304703-304955—that had been removed from available sales inventory. Porsche then issued RS Ex. 13/66, the bulletin that instructed factory technicians of the changes to be made to the 253 cars that would create the new model to be offered: the 1967 Porsche 911 Deluxe RS.
    The factory Kardex build sheet for Serial No. 304769 verifies this car as one of the 1967 Porsche 911 Deluxe RS models produced in European configuration, and it retains its matching-numbers engine, Engine No. 907962. The Ivory color combined with a Kunstil Schwartz Pepita interior and sunroof are all additionally verified on the Porsche Certificate of Authenticity accompanying the car. The handwritten notes on the Kardex show that of the 253 cars, this car was even singled out for additional desired internal modifications.
    The changes from its original configuration were for further factory use from July 19, 1966, through November 10, 1966. The modifications to this car included the transaxle gears being changed to the new 911S ratio. The original engine block received the S crankshaft and S rods, marked and pulled from the best weight-matched produced parts available from the top 5 percent of production. Model-year 1967 S piston and cylinders with the smaller second ring allowed for higher compression, while ‘67 S heads with larger ports and 1mm-larger valves, ‘67 S cams, forged rocker arms and the ‘67 S IDS Webers with the secondary accelerator pump included combined for nearly 200 HP with a high state of tune from the race-bred nature of Porsche's soul.
    The body received enlarged rear wheel arches to test wider offset wheel-and-tire combinations, and it came with wheel spacers and extended studs for increasing the rear track. This was a common procedure with factory trial cars in the workshop, both prior to and continuing at this time, as development of the R model was soon to come and momentum was building toward the desired RS model's creation. With all of the modifications completed and 7,600 kilometers of testing run, the predecessor to the first Porsche RS was styled by these design changes.
    The unique history associated with this chassis leaves a fine example thought to be one-of-one and very unique among the 911 Deluxe RS cars built. This car received a sympathetic and meticulous restoration by a respected marque specialist that cost $175,000. The numbers-matching engine was disassembled and deemed to be in excellent condition with only new bearings, piston rings and seals being replaced. Meanwhile, carburetors were rebuilt to proper specifications and the transmission reconditioned with new synchros, a clutch, pressure plate and flywheel replacement. The original interior, with the exception of the new headliner, has remained untouched and reflects the honesty and pristine condition of this car, including the original seats. The body is laser straight with uniform gaps and flawless paint application. The underside is detailed and the suspension was restored after being completely removed. This Porsche features the original four-headlamp screw European light configuration restored to as-new and matches the four-corner European lens display.
    This is an opportunity to own a first-generation RS, one that is an ultra-rare, highly optioned, historically significant and Kardex-documented car. This beauty achieved exceptional use in its first months of completion, and has today accumulated only 72,000 original kilometers. The sticker on the windshield reads “STUTTGART INSPECTED COMMUNITY,” and is original to the car.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  10. #30
    Why would the city of stuttgart have a sticker in english?
    ~J~
    air cooled only
