Results 1 to 10 of 11
Thread: Correct Hirschmann Manual Antenna for 911 1965/66
    Hello,
    Looking for the correct Hirschmann Manual Antenna for my 911 BY 1965 MY 1966 car.
    I read that Hirschmann is still making this antenna...
    Also that the correct and original antenna have a black knob on the antenna.
    And that the new ones have a metal knob...?
    Anyone experience of buying these with Koenigs-Klassik.de?
    Some stuff that I need to watch out with? Advice?
    Maybe image of the correct antenna?
    Senior Member joegt3cup's Avatar
    Mar 2004
    Colebrook CT
    I am not aware of any source where you can get a 100% correct one new.
    I have no experience with Koenigs-Klassik.de or what they offer perhaps someone else can add to this.
    Joe Annicelli
    Early 911S Registry #751
    Polo Red/Black 1967 Porsche 911S Coupe "Walter"
    Black/Red 1967 Alfa GTJr. Coupe "Nero"
    Italian Red 1994 Ducati 900SS/SP looks fast standing still
    Italian Red 1957 Gilera 150 Sport
    Ahhhh the sixties... I envision myself one early Saturday morning wearing plaid shorts, black shoes with white socks smoking a cigarette heading to the hardware store to buy a bag of nails.
    SWB cars are an acquired taste however once acquired theirs no turning back.
    Nov 2002
    San Dimas, CA
    As to what a correct Hirschmann antenna should look like, here are photos of the broken antenna that was with my 1965 911 when I got it:
    Name:  2016-04-08 12.25.32.jpg
    Name:  2016-04-08 12.26.10.jpg
    I can't guarantee it's the original antenna but it's definitely old enough to be original.
    And here's a photo of the original re-chromed bezels on a new antenna (which is close but not exactly correct):
    Name:  2016-04-08 12.26.59.jpg
    About the black versus metal top:
    I think you get both. The antenna's designed to "lock" so that vandals can't damage it. It should come with two little keys:
Size:  10.0 KB Name:  hirschmann_auta_4090l_unlock.jpg
    To "lock" the antenna you push it all the way down into the base and to "unlock" the antenna you use the little key to pull the antenna back out.
    But, the antenna comes with a little black cap to prevent it from going all the way into the base and "locking." Until you remove (or lose) the black cap you can pull the antenna up without the key.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    I have found these on the web.
    Don't know if these are original or almost 99% original for a 1965/1966 car.
    But looks a quite the same as the picture Jim posts on the yellow car
    There are two different types of antenna.
    I will post the link so you can see them.
    Advice would be great.
    Type 1:
    http://www.stoddard.com/90164530100.html
    Type 2:
    http://www.stoddard.com/90164530101.html
    Sep 2006
    La Quinta
    Type 2 looks close.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    John,
    Thanks!
    I suppose that the little chrome ring just under the plastic cone is a little bit less big?
    Nov 2002
    San Dimas, CA
    The big difference I see is the black plastic "truncated cone" above the chromed bezels is taller on Number 2: Hirschmann Radio Antenna, Small Base, Black and Chrome for 911 912 up to 1977 which is what I'm used to seeing.
    There aren't many period photos showing antennas. I do have a Porsche of America Brochure, "Go ahead. Drive It." The brochure's undated but those are clearly Model Year 1965 cars inside (you can see a scan at The Samba where it's called "1966 Porsche 911 Brochure"):
    The resolution's barely adequate but they do show a black "truncated cone" above the chromed bezel on the antenna base so I think Number 2: Hirschmann Radio Antenna, Small Base, Black and Chrome for 911 912 up to 1977 is a better match (for just $235.01).
    The Stoddard's descriptions imply the bases of their two antennas have different sizes but they don't give dimensions. You could always call them and ask what "large base" and "small base" really mean.
    Jim Alton
    Torrance, CA
    Sep 2006
    La Quinta
    Here's the original on my '65 with the black cap. Hope this helps.
    Registry #983
    R Gruppe #741
    Could a Auta 2400 LS II of Hirschmann be correct for a 65/66 car?
    Here a picture from someones pictures library.
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by Michael Winters View Post
    How correct do you need it to be? I can see two differences:
    1) the "truncated cone" above the bezel on the old, broken antenna that came with my car is sort of convex, almost a truncated parabola:
    The "truncated cone" above the bezel on the Auta 2400 LS II in your photo is straight-sided or maybe slightly concave.
    2) the Auta 2400 LS II is a universal antenna and adjusts for the angle at which it penetrates the fender. The original antennas had a sort of a wedge.
    But, once an Auta 2400 LS II's installed in your car it will be really hard to tell from an original. Finding a true, original Hirschmann antenna matching the part number and vintage of the ones installed at the Porsche factory will probably take a lot of money and luck.
    I recall Victor Miles selling a really nice red tip Hirschmann antenna at the Phoenix Club a while back for just $ 950.
    Jim Alton
    Torrance, CA
Tags for this Thread
