Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Rain Shields
  1. #11
    Jul 2011
    Chicago Area
    Quote Originally Posted by Harvey Weidman View Post
    I always thought the originals had only the right one bent for clearance?
    H
    Probably easier to make them one way when doing reproductions.
    Mike Fitton # 2071
    2018 911S Carrera White
  2. #12
    i am not sure if my pic will upload, but we made flat tops and bent ones, the bent ones are more common ones
    Early Porsche Reproduction Parts
    http://sycipworks.tripod.com/
  3. #13
    Jul 2011
    Chicago Area
    Quote Originally Posted by jtkkz View Post
    I am assuming the right one needs the bend so the engine lid will close, the left one can be straight, correct?
    Mike Fitton # 2071
  4. #14
    I agree with Harvey, my understanding is that the right side shield was bent down to clear the lid and the other was flat or possibly the driver's side is turned around to clear the slope of the rear deck below the rear window like the Solex air cleaner housings were. The race engines used taller intake manifolds than OEM and the Solex engines also had tall intake manifolds so a little bend in the rain shields would clear both deck lid & forward sheet metal.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
  5. #15
    I would buy a set
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  6. #16
    Oct 2010
    Florida
    I bought mine from someone here. It's been a while.
    My problem is the filtration. I use the little nylon booties that probably don't do a whole lot. We really need something that filters out particles larger than 10 microns. F1 filters actually filter out 7 micron particles. Just for reference a grain of sand is 50 microns.
    Richard Newton
    Air Filtration 101
  7. #17
    Lightbulb
    Here's more to add to the mix.....
    - First photo of Steve Childs' T/R ... I'm pretty confident that the stuff on the engine was part of the 'kit' the Swed's got in '68.
    - A photo I've posted before of the R that the Registry's Michael Hammond was trying to sell at Westwood Porsche/Audi (with no takers) in about '71.
    Oct 2010
    Florida
    The conclusion here then is: If you have bent shields on both sides then the car is wrong?
    This has a impact on people who are selling these items. When I bought my reproductions I just assumed they were correct. My mistake.
    Richard Newton
  9. #19
    Jul 2003
    Santa Cruz, CA
    Are the pick up points for mounting symmetrical on the carbs? That would be an indication whether flipping a side
    Is even possible and helping determine the odds for one Porsche number versus two.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  10. #20
    May 2005
    Oroville, CA
    The white with red car has short manifolds.....You only need the hats bent when you use tall manifolds...
    H
