Thread: Which Engine ? part2
    Nov 2003
    Santa Monica CA
    Hi all- which engine would be "more fun". 2.2S with 70.4 crank or a 2.6 with RSR 92mm pistons on a 66mm crank.? I like to rev. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Banned
    Nov 2004
    Scottsdale, AZ
    Chris,
    About 30-40hp difference given the same comp, cams, intake, etc. and they will have similar "rev" tendencies. (And anyone who says there's a meaningful difference in this area between the two is full of crap.) If your idea of "fun" is being able to throttle steer the car, then 2.6 is the way to go.
    Your biggest decision would be whether you want to violate the case with enlarging the spigots.
    If you want a bulletproof combo use a sand cast case, not mag.
    Nov 2003
    Santa Monica CA
    Yes one of the main issues is whether to enlarge my 73 1/2 911T 7 R case. or keep it stock since the track people like the case. BTW is there still a Club Sport series that builds these 2 liter engines and would be looking for such a case? Chris
    Banned
    Nov 2004
    Scottsdale, AZ
    Always a market for 73.5 case.
    Gotta be worth at least $500.
