Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: exposed oil lines
  1. #11
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    72, but that was a weird year. For all intents and purposes, 73 was the first year for exposed oil cooler lines as we expect to see them.
    Jim
    71 911T with exposed oil cooler lines
    Yes, my 72 has a set of lines the return of which extends to the rear of the console where the thermostat resides
  2. #12
    Jim
    C'mon, Jim. You know the thermostat was mounted to the tank in 73.
    72 lines are one year only, 73 lines are one year only, 74-84 lines are what you expect to see, and 85-89 lines are almost the same with only slightly different bends at the RF fender.
    Buy OEM lines from Porsche. They fit perfectly and don't leak. You can make the clamp standoffs and weld them to the rockers or just punch a hole and run a long bolt. That's how we did it before the cars had any real dollar value.
    -Marco
    TLG Auto: Website
  3. #13
    Jim
    My 69S also has them exposed. FWIW
    Cheers,
    Mark
    Early S #2826
    Garage:
    '73 E (2.7RS replica) - sold
    '94 968 Clubsport M030 - sold
    '67 250SE Cabriolet - sold
    '71 Skyline GT - sold
    '69 911S - sold
    '73 911T/RS
  4. #14
    Wow, can you post pictures of that, since they were in the rockers then. Have you had the car from new?
  5. #15
    Jan 2011
    DFW TX
    Quote Originally Posted by Mr9146 View Post
    But they don't fit perfectly on pre-73 cars without the recesses in the front fender well. They fit but the jack "bump" will be offset which to my eye is certainly not perfect! I lengthened mine with Ed's tutelage to overcome this problem.
    Mike
