Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Bilstein Green dot jacks
    Bilstein green dot jacks - differences
    Hi all,
    I am trying to find out the correct type of jack for my 1974 2.7 Carrera MFI that I have recently bought.
    Hopefully some of you can can help as I have searched to find a definitive answer but had no joy.
    From what I have read there are 3 main types:
    1) with a lollypop handle
    2) with a small teardrop shaped pressing in the handle
    3) with a longer teardrop shaped pressing in the handle
    There is also another version with a larger base but I gather that is for much later cars.
    The vehicle was delivered in November 1973 and is a UK spec car.
    Any info on this would be greatly appreciated.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    have +30 different jacks--so once you know the correct type i`ll have a look.
    Not sure if this helps but my April build '73 has your second example...
    Good luck on finding the definitive answer.....
    It all helps
    I have seen threads where the 2nd type is as used in the 1973 RS.
    Maybe the 2nd type ran into 74/75 cars and then they switched to the 3rd type.
    Trouble is I have seen threads saying type 3 is the early type as well...
    Yes hopefully the jack experts will post the definitive answer!
    Oct 2010
    Florida
    My 1973.5 has the 2nd type.
    I really don't like using these jacks. Everything has to be perfect in order for them to work properly.
    I carry a small bottle jack in the car.
    This is what I use in the shop.
    Richard Newton
    A $1,500 NASCAR Jack
    Ha ha it's not for using, it's for completeness.
    I have one of those big jacks too :-)
    After a bit of research I think I may have out the differences in the later jacks thanks to a 914 site: http://www.p914.com/p914_tools_jack.htm
    1972 to early 1973 has the lollypop curved handle - top image
    1973 to early 1975 has the flat handle. 2nd image
    Late 1975 to 1976 has the flat handle and the cap is secured differently. The cap has 2 dimples on the top. 3rd image
    The last images show the 72-76 jacks side by side in date order running left to right
    I need to get out more!
    Oct 2010
    Florida
    This helps a lot. Here is mine.
    Name:  911 Jack 2.jpg
    Name:  911 Jack 1.jpg
    Does anyone actually check these jacks for correctness during judging?
    Richard Newton
    Lightbulb
    My April build '73 has this one, like Richards
    That matches :-)
    Just to add the handle has the small teardrop shaped pressing in the 73-76 jacks and all jacks have a pressed tongue.
    Later versions were revised with a cast tongue and at some point the handle changed to have a longer teardrop shaped pressing.
