Here is the engine I don't know who rebuilt it or what they have done but it has a tag saying rebuilt timing and carb adjustments done
So it's "rebuilt"'but you have no invoice, list of parts, rebuilder's name, or warranty?
Pig in a poke.
What you have is unknown hardware for sale and unless you get lucky with engine number bingo, value is probably not what you're hoping.
But in spite of that, I wish you the best of luck.
I would value the engine at 15k +/- 5k.
A big warning sign is whoever built the engine used the wrong color shroud. With no provenance buyers will wonder whether the builder knew what they were doing.
So right now it's basically a role of the dice.
Find the car this goes to, now your talking !
1962 356 S Cab gone
1967 911S Coupe
2008 RS60 Boxster gone
1973.5 911T targa soft window Gone
Runge 008 Gone
2002 996 TT x-50 Gone
2016 Boxster GTS pts gulf orange
1969 912 SWT pts green
Can I be FRANK with you ?
Live everyday like it's your last .
Eventually you'll be right.
Where are you located?
member 3143
Had a few GREAT cars. Do I miss any of them? NO!!!
However, I am Glad to have the one I have now:
My wife Blanca NFS
1967 Ford Fairlane 427 4 speed R code 1 of 72 cars
1959 356 SunRoof Silver/Green
Those aren't IDS carbs either.
Australia New South Wales
So can anyone confirm with the numbers on the engine that it is a 2L?
Also how would I find the right chassis number that it belongs to
The best that can be confirmed is that it was originally built at the factory as a 2.0L. With these old engines, and having been rebuilt, there is no telling what is inside without a tear-down.
You can look for casting numbers on the heads, and cylinders to provide clues if they were changed. You could pull a spark plug and see if you can determine the stroke of the crank.
member 3143
My wife Blanca NFS
