Thread: Engine lid grill difference
    Jul 2008
    near Ottawa, ON,canada
    Ok I am working on details while its freezing here
    I have 2 engine lid grill
    I know one is wrong as it is a 5 bar grill and ot was painted so i am redoing it
    It can be taken apart to be stripped and polished
    The aluminum bars have a T shape to them
    With a depression in the middle and the finish is polished aluminium
    Which i know is right for up to 68
    But 68.5 and later is not clear
    I read that there is a 68 69 only thing
    The other grill i have is all black and the bars are U shape
    So is this a 70 and later or the correct one
    Is the right one a T shape with no depression and polished or a U shape polished
    The U shape does not look like it can be taken apart
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Jul 2008
    Ok after a bit of further reseach i found that the griĺl i have is in deed a late 68 which is correct for my car
    Now 2 more questions
    Were all grills were polished aluminium or were there some black ones
    If they are all bright how do you remove the bars without mangling them
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Late 68 & 69 are shinny & have three vertical straps. 70 & 71 are shinny & have five verticle straps. 72 & 73 are black and have five verticle straps......cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Jul 2008
    Ok so i know it needs to be shiny now and that u have the right grill
    In order to strip it how do i remove the bars without mangling them
    Anyone done it before successfully
    While the grill looks simple restoring it is a major undertaking. I can almost guarantee you'll break parts in the dis-assembly. I have at least twenty-thirty hours in mine so far and it still doesn't look that great.
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    The U shape bars can be lifted off for refurbishing and replaced and of course they are numbered to make it easier for reassembly.
    Jul 2008
    Are they glued in
    Press fit
    Whats the best way to take them out
    Jul 2008
    Ok so i decided to give ot a try after carefull examination
    I used a small precision screw driver to spread the bar . The sides are easy but the middle is a bit tough because the mesh blocks the way
    But after careful prying its comming apart easily
    And you can even see the original crimp marks at each location
    I will strip all the bars paint the mesh and recrimp
    I dont know what the original tool looks like but i am sure a a pair of carefull grinded pliers will do the trick
    More to follow
