Results 1 to 2 of 2
Thread: 1966 911s engine & tranny??? I have
    Junior Member
    Jan 2017
    I'm trying to find a value of a longblock and tranny I have. The numbers I have are *907814* and 4679 that number is by the oil tube.
    Oct 2008
    Burford, ON, Canada
    That is a 1966 standard 911 engine with engine type 901/05; it has the aluminum crankcase. Value depends on how complete it is, so photos are useful.
    Look for the trans serial & type #'s on the bottom rib of the main case under the diff; this is the lowest part of the trans when installed. Just watch that it does not leak out of the vent when you turn it over.
