Thread: 75 911S fender clearance
    Aug 2016
    Eastern North Carolina
    I have 6 by 15 cookie cutter rims using 195 65 15 tires. Can I use a 205 tire (or larger) on my rear rims without interference on my rear fenders? This is a street car. Any help is appreciated. Thanks
    Jan 2011
    DFW TX
    A 205/60-15 will fit fine on a 6" factory wheel. A 225/50 may be tight.
    Senior Member obscene's Avatar
    Sep 2015
    PA
    205 should be fine. I had 225/50 on my '77 for a while and had to run a fairly aggressive negative camber to avoid rubbing.
    Benny and the jets - My '77S Rebuild Adventure
    Aug 2016
    thanks guys
