Thread: Help with Correct OEM TTG Hella fog lights TN4?
    Are this the correct TTG Hella fog lights for a 1970 911?
    I have search and I am confused with TN1/TN2 & TN4
    And there is also some very good made repros.
    Looks like there was a US versions and a ROW.
    I will really apriciate if someone can help me clarified a little this issue with TTG lights.
    Best Regards
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Rino71 View Post
    Best Regards
    That is the correct TN4 lens for the US TTG fog. Uses a tungsten bulb and is completely different from the ROW halogens with the exception of the overall dimensions of the light. Whether the rest of the light is fully correct for US Fog or not cannot be determined from your pic. There is no repro of the US version, only the ROW halogen.
    The TN1/TN2 lens can be used as a replacement for the TN4 but is not technically correct.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Great Info. Thank You!
    Here sone more pictures.
    I want to install a yellow more fog lamp type bulb
    In this lens but I can't find them. Any suggestions?
