Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Accurate "RS" door cards?
  1. #11
    Keith, I see no reason why you couldn't make your own from cowboard and black vinyl. Pretty basic really.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  2. #12
    Quote Originally Posted by Cornpanzer View Post
    I'm considering it, once I understand all of the correct details. Although if I do, I'll be having a run of cards die cut, foam donuts & straps made, etc.
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
  3. #13
    Apr 2008
    Virginia's Blue Ridge
    Quote Originally Posted by keith View Post
    And the rest of us will be thanking you for it!
  4. #14
    AppBiz already produces door cards, although not correct material. If you want original, why not use some factory cards off a 74 or later, they are plentiful?
    I just donated a set to my mechanics stash.
  5. #15
    We make these which are patterned on the original RS cards which were used without door tops.
    Waterproof foam board, inner self-adhesive moisture barriers, Fiat 500 pull handles and jack nuts for fitting and leather straps for opening.
    We use screw cups from Wurth which are crimped in the inside to prevent them from punching holes in the vinyl and are nickel Plated.
    We also make a version for use with door tops
  6. #16
    Chris, your straps look to be the correct dimension also (as expected) - that is the detail that is escaping me on the internet.
    keith
    r gruppe # 436
  7. #17
    Bumping in conjunction with this thread
    keith
    r gruppe # 436
  8. #18
    Senior Member DavidRS's Avatar
    Oct 2011
    where ever I am
    wondering whether anyone can tell me the vintage of this door card. have pulled the radio and want to eliminate the speakers, so i need new cards. The ones that i see do not have the door latch mechanism in the door center like mine. Car started life as a '69 912.
    My Inspiration
    '86 44 Turbo, black/red,7's and 8's fuchs, autothority - sold (rocketship)
    '97 Boxster, first delivered in DC Metro, silver/red -sold (huge mistake to buy this one)
    '99 C2, silver/black, RoW M030, limited lip, short shift - sold (good ride, but...)
    '69 912, 3.2 with all the trimmings
    (finally got air cooled)
    Early 911S Registry Member 2044
