Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Is it a 2.4 or a 2.2?
    My '72 911T 2.4L has a popular period upgrade of 2.2S P's & C's to raise the compression (making it a fun car!)...my question is: Is it still a 2.4 or is it now a 2.2?
    I know that the difference between a 2.4 and a 2.2 is the length of the stroke but how did they do this? Crankshaft? Length of the rods? Pistons?
    Thanks in advance for any input!
    '66 911 - Light Ivory | Early '66 with Solex Carbs
    '72 911T - Aubergine originally | now Bahia Red | "S" options | 2.2S P&C's
    Feb 2016
    San Clemente, CA
    Quote Originally Posted by TWJ View Post
    I would most certainly think it is a non stock version of what ever the case says it is.
    meet in the middle and call it a 2.3
    ~J~
    air cooled only
    Senior Member 767driver's Avatar
    Oct 2008
    Parkton, MD
    Knowing the bore and stroke you can use this...
    http://performancetrends.com/Calcula...splacement.php
    Using the 2.2L bore of 84mm and 2.4L stroke of 70.4mm you get 2.341... or 2.4L in Porsche-speak. Both the 2.2L and 2.4L use the same bore. The 2.4L has a longer stroke at 70.4mm vs 66mm for the 2.2L.
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Thanks for sharing the knowledge Lee!
    Oct 2008
    Parkton, MD
    Anytime...I just hope it's correct!!!
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    But is the larger cc got by longer rods or longer crank throw ?
    Apr 2003
    NoCal
    Gents, You are making this too hard. The 2.2 to 2.4 is via longer throw crank. The 2.4-2.7 use the same crank and this crankshaft is the first use of the forged crank for all versions. In terms of the specific engine that started this discussion, think of it as what it is- higher compression pistons. With Porsches it is usually done as a piston/cylinder "kit", which is a simplier way to get the clearances right. A 2.4S with 2.2S pistons will make a 2.7 RS driver miserable and has a much sportier feel. [I have a 2.4S long block in pieces and got a set of 2.2S pistons for the day I get off my duff and build it. :-> ]
    Feb 2016
    San Clemente, CA
    nerds........
    Oct 2008
    Burford, ON, Canada
    No change in displacement from the 2.4 since they used the same bore and stroke of the 2.4; the 2.2 evolved into the 2.4 via the longer stroke crankshaft. Rods did change I think. However the big deal is that the piston crown is bigger which magically increases the compression ratio over both the 2.4 and the 2.2. Thus you have a fairly high compression engine with more power with stock parts.
