Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: FS: Set of 5 Gauges '70E one year only
  1. #11
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    the tach and the Bosch resistor are tested.
    tach,tank/oil and oil pressure/temp gauge are cleaned, bezel painted, glas polished
    I have a nearly matching untested speedo and a matching clock without glas.
    If there is need to buy a set of 5 and the buyer definitely buys the 3 refurbished gauges I will send the speedo to been refurbished. I do not have a glass for the clock. Are there vendors that sell those?
  2. #12
    May 2014
    South East USA
    how much for the tach? scott in california
  3. #13
    Apr 2016
    Stuttgart, Germany
    CE2E5453-B2E3-4671-9A04-6B19C7459218.jpgJust received the small and large Oil/Gas gauges from restauration
  4. #14
    Junior Member
    Feb 2016
    NT Australia
    Hi Dirk PM sent
    RHD 1970 911E
  5. #15
    Apr 2016
    Stuttgart, Germany
    sold local
    can been closed
  6. #16
    What do you mean by 'one year only'?
    Were 69 and 71 gauges different to 70?
  7. #17
    Quote Originally Posted by blue72s View Post
    69 gauges still had the brackets with knurled nuts and threaded ends on the back. not sure of the difference between 70 and 71
    ~J~
    air cooled only
  8. #18
    Apr 2016
    Stuttgart, Germany
    J. is right on the 69-70 and beginning with MY71 they stopped using the 2years only ballast resistor inline to the tach.
    also the ending of the tach changed from .00 to .01
