Results 1 to 10 of 11
Thread: Correct Color for Braided Brake Fluid Reservoir Lines?
    May 2006
    CT
    What is the correct color for the cloth braided tubing that connects the two brake fluid reservoir exit lines to the plastic feed lines for the master cylinder on a 1970 911?
    The photos I have seen and all the old reservoirs I have in my stash have black cloth tubing. I was told by someone knowledgeable that they are supposed to be blue.
    Which is correct?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Nowadays when you buy the hose from ATE (for exactly this purpose not fuel line) it is blue
    Cheers
    Uli
    May 2006
    CT
    I know you can buy it new in either blue or black. My question is what was the correct original color?
    Tom Butler
    1973 RSR Clone
    1970 911E
    UAI is correct,,,,blue IS for brake fluid,,,,but they came black back in the day.
    I recently bot brake fluid hose from Porsche, it was black.
    May 2006
    CT
    I dyed half my length of blue tubing black.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Unrestored RS #197..pretty sure the line was original as it was very old very hard and a bit frayed...and black
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    May 2006
    CT
    Thanks for setting me straight
    Tom Butler
    1973 RSR Clone
    1970 911E
    Jan 2011
    Horb a.N. Germany
    Good to know - when you're searching for black lines buy from Porsche
    Banned
    Nov 2004
    Scottsdale, AZ
    More to it than just the color...
    http://www.early911sregistry.org/for...ir-hoses-black
