What is numbers 960953 on my 1969 Porsche 911S
Is it the build numbers?
Where are you seeing this number?
Peter Kane
'72 911S Targa
Here`s a photo on the engine Thanks
Thank You Very Much.So It Looks Like My 1969 911S Is Not Matching Nos.
Is My Car Still Worth Anything?
get yourself a COA on your car.
www.tcspeed.com
Where do I get COA, Thanks
Yes . When I go to my warehouse,I`ll have more Photos & Information
Hm/weeeeeeeeeeeeell --- why do you say that?
The number you've shown is only one of several that appear on a 911. Here are some pics + notes . . .
1) Engine number --- the one in the pic that you've already provided
Vehicle identification number --- stamped in several places . . .
2) . . . into an alu tag riveted to the pass-side of the front 'slam' panel --- the one that the front hood latches to
3) . . . into a raised pad located on the sheet metal of the pass-side of the front trunk floor, between the gas tank and the inner fender
4) (sometimes --- if the car's been registered in CA) . . . onto an improvised decal/tag/whatever located an 'externally visible location' . . . here, on the drivers' side A-pillar
5) Transmission number --- into a raised cast pad located on the bottom of the trans case
6) Production number (aka the 'secret number') --- stamped into the dash panel's sheet metal, up behind the ash tray/pass-side lower dash pad
Here's a gallery . . .
http://www.early911sregistry.org/for...hp?albumid=155
The best way that I know of to verify the specific details of any 911 would be to get what's colloquially known here as the Kardex --- here's a thread . . .
http://www.early911sregistry.org/for...-of-the-Kardex
It'll provide the 'numbers' that you're interested in --- along w/ lots of other stuff . . .
http://www.early911sregistry.org/for...st-Your-Kardex!!!
(IMO --- CoAs are nice-enough --- but you really REALLY want to get the Kardex)
Anyway --- HtH . . . and welcome aboard
www.tcspeed.com
