Page 1 of 10 123 ... LastLast
Results 1 to 10 of 96
Thread: Engine Sound Pad (~1970 and up)
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    In search for a correct 72 engine sound pad I bumped onto material to make a couple myself.
    I used the current porsche supplied foam versions for the pattern. That was the only thing I had at hand to work from. The material I made them from is the jute with PVC like the ones used from around 70 and onward. I believe the outer material grain is pretty close to what was used in 72.
    These are all hand cut, so don't expect a factory perfect stamped one. It took me about an hour each to mark and cut. Add material cost and shipping cost to the US and you know I'm not getting rich making them. I only have 5 to spare.
    $165 shipped to the US. (Price adjusted due to higher shipping and material cost)
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Looks nice, I'll take one, pm sent
    bob moglia
    '72 E sunroof coupe
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    I'm in need. Please send payment info. Thanks,...cliff
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    Don't need one but, nice work Alex!
    Sep 2013
    Vancouver, WA
    Looks pretty good. I assume you've seen the photos I posted of an original 1972 sound pad on another thread. The 72 sound pad was Gray and had a basket-weave pattern on it.
    http://www.early911sregistry.org/for...ight=Sound+pad
    Mar 2006
    8903one
    I don`t see the gray! Looks blak.....cliff
    Jan 2007
    Netherlands
    In your post you state that there was foam on the back. If that was the padding itself, I wonder if it was a 72 pad.
    In this tread, a 70's was with Jute on the back:
    http://www.early911sregistry.org/for...gine+sound+pad
    Quote Originally Posted by Gearby View Post
    Rgruppe #674
    Sep 2013
    Vancouver, WA
    I can say with virtual certainty that my pad is original. The reason for this is that my car has not been driven since 1986. Ive owned the car since 1993. I've had long discussions with the previous two owners, with the first having purchased the car in 1976. The foam backing on my pad is quite disintegrated. My sound pad is not like that one in the thread you mention. It has no thread in the pad whatsoever. Foam on the back with a vinyl like outer surface with a basketweave texture.
    Not sure if it helps/ is relevant but the photo Gearby posted in link at post #5 looks similar to the pad on my 12/ 72 production 1973 model year car -- which is likley original. The foam backing disintegrates to a dust and it is sort of basket weave imprinted pattern
    Sep 2013
    Vancouver, WA
    For reference, my car is a 1/72 production.
