Results 1 to 10 of 12
Thread: Been MIA, but I finally caught my tail...
    Jun 2011
    Mound, Louisiana
    Arrow Been MIA, but I finally caught my tail...
    Or the tail I have been chasing. After sorting ignition problems then starter problems... I finally caught my tail by back tracking what I DID!!!
    Now I need to replace the rear calipers me thinks. After a short ride with the infrared gun LH rear was 141F and RH was 341.
    So... Eric did such a nice job on my front calipers, I am thinking of buying the new alloy calipers he offers for the rear, and putting the old ones on the shelf.... For later..
    I mean you loose unsprung weight and weight off the rear. Can anyone give me an reason not to?
    Picture for proof it still goes!
    Paul Harrop 12.5% German.
    Early S #2059
    Nope can't think of a reason not to,,,but first how about the rear flex hoses?? how old??
    Jun 2011
    Mound, Louisiana
    All brake hoses are new. I did that chore when I put a repaired transaxle/clutch, etc. What I also need is a set of J6x16s. My tires look great to be 25 yrs old, but...
    Thanks Chuck.. My tach is working again.. Now for the speedo!
    http://www.early911sregistry.org/for...ght=tachometer
    Early S #2059
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by dummkopf View Post
    Glad you surfaced Paul but I don't think anyone wants to see your Speedo.
    I could be wrong; Rick likes photos of everything.
    Jun 2011
    Mound, Louisiana
    LOL!!! Thanks. Some one told me you might have a set of map pockets or two?
    Early S #2059
    Jun 2011
    Mound, Louisiana
    I'm back again, and it is running like a clock! 16 J6s with Pirelli sticky shoes!!! Never had any stickies like these... Man they do pick up pea gravel....
    Sorry for the missing photos.. Photobucketed...
    The factory green window tint is off the hook as you can see!!!
    Early S #2059
    Jun 2011
    Mound, Louisiana
    I see my welcome back committee is back in force!!!
    So anyone have a speed calculator? I awoke my relic from its slumber only to fine the speedo is inop. I drove it 60 or so miles today. For the most part it ran like a top. I do have some throttle linkage issues though...
    Anyway, how fast is 5K in top gear? 1972 S... I am thinking 125+?
    Now I remember why I love 911s like I do!!!
    Early S #2059
    depends on diameter of your wheel tyre combo
    Jun 2011
    Mound, Louisiana
    Thanks David.
    205/55/16, so what is that? 24.5" or so? What is the final drive ratio for a stock 915? With a search I come up with 4.43 and a 5th gear of 0.76? So that would be around a buck 10? Good enough!!! Temp ran around 180 max and the oil pressure 60 or so. 20 at an idle. The more I run it, the better it seems to run. No chains or other rattling. I might need to run the valves. It drives like a dream! The only thing is I think I have a bad ground on my turn signal LH front. The indicator will blink once bright and then blink both right and left indicators dim. Have to love the Germans!!!
    As a side note, because of "sometimers" I forgot to install the inside boot for the shifter shaft. And out of ignorance I didn't install a new one on the outside.... So it was pumping a bunch of hot, sometimes smelly air through the shifter tunnel at speed... Oh well. Lesson learned.
    Early S #2059
    Aug 2009
    edmond, OK
    I just use Waze on my iPhone to tell me my speed. Any of those GPS apps should be able to work.
