Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Blaupunkt Frankfurt V-Code 64/65
    Jul 2011
    Chicago Area
    This Blaupunkt Frankfurt AM/FM radio was just completely gone through by the radio doctor in St. Augustine, FL and is in like new condition, everything works. It is a V code so correct for 64/65 911 and probably late 356. Price is $650 shipped in the USA.
    IMG_2858 (1024x768).jpgIMG_2859 (1024x768).jpgIMG_2860 (1024x768).jpgIMG_2861 (1024x768).jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Jul 2011
    Chicago Area
    Bump for excellent radio.
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    The radio doctor's list of what was done in servicing this radio:
    - Implement audio amplifier to replace defective output transformer
    - Rewind burned-up power choke
    - Replace burned-up bias diode
    - Replace melted voltage switch plug
    - Replace all out-of-spec and end-of-life capacitors
    - Replace dial lamp
    - Provide new fuseholder and fuse (definitely!)
    - Provide speaker harness
    - Thoroughly clean both radio and power unit cases
    - Clean/lubricate volume control to eliminate electrical noise
    - Clean all circuit boards
    - Disassemble, clean and lubricate the tuner and the Station Selector mechanisms
    - Refinish dial pointer
    - Refinish band selector indicator
    - Clean/polish dial crystal
    - Clean dial crystal backing plate
    - Clean tuning dial background
    - Clean/lube all band switch contacts
    - Clean Station Selector PBs
    - Refill Station Selector PB markings
    - Ensure all cables/connectors are reliable
    - Realign all tuned circuits
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Still available.
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Forgot to mention that this radio is setup to run on 12v power.
    Mike Fitton # 2071
    Knobs are for 356, is it also working on 6 volt?
    Still no answer so it will not work at 6 volts
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by yellow356 View Post
    I don't know why Mike Fitton's being unresponsive. I'm pretty sure V-code Frankfurts can switch from 6 to 12 volts. Here's a photo of the "power box" of my US-band Blaupunkt Frankfurt (V715137--identical to the one for sale save mine has 911 knobs) in place in my 911:
    You can make out that "12" peeking through the cover beside the "V" that's the 6/12 volt selector in 12 volt position. You should also be able to switch from negative to positive ground (as practiced by Joseph Lucas, the Lord of Darkness).
    You should probably contact Mike Fitton directly to make sure but US-band vintage Blaupunkts are pretty rare and everybody wants them because European FM now goes up to 108 MHz.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Aug 2009
    SF Bay Area
    Yes, the knobs are 356, but the face plate is 911. If it works on 12V, there is no reason why it wouldn't work on 6V. He did mention that the voltage switch was replaced.
    Can't we all get along?
    Jim
    PS: I have no dog in this fight.
