Results 1 to 10 of 17
Thread: 1964 early 1965 tall Engine Grille
    Dec 2011
    Monroe, WA
    Used very early in production, research indicates about 600 cars used this grille and the proceeds should hopefully help fund a new roof for my house
    No broken studs, needs restoration. $6500.00
    "Fahr drauf, bremsen ist feige!"
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Could also fund a new Ruf....glws
    Dec 2011
    Monroe, WA
    Quote Originally Posted by Cliff View Post
    Yeah!
    Maybe Herr Ruf will see this and just absolutely HAVE to have it!
    Dec 2011
    Monroe, WA
    Update:
    If it makes any difference, all the crossbar nuts have been soaking in Kroil for 3 months and have all been loosened, so no broken pieces to replace.
    Dec 2011
    Monroe, WA
    901 Grille
    I spent several hours inhaling MEK cleaning the updated flat black paint off my (kinda) rare 901 grille.
    Vast improvement!
    All fasteners are loose, none broken. Still has a few bends from the last 53 years, looks like someone tried to install a badge or something and broke some of the mesh.
    Attachment 429328
    Dec 2011
    Monroe, WA
    901 Grille still available.
    I'm open to the suggestion that I might have priced this rare piece of P-Car technical engineering and artwork a bit too, let's say, loftily.
    bump please and open to realistic offers, whatever that is.
    Still need the house re-roofed!
    Apr 2011
    N.Calif., south of SF
    Curious- and no offense to ptrsbtrs, how does one tell what generation of 911 this grill is from.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by Haasman View Post
    the beams are slimer and taller on the early one--like the one advertised. the easy way to distinguishe both versions is to have a look at the rivets.(last pic in the ad)
    on the later version they are in the center
    Hi Franz,
    Good "spotters guide" but here the proof is in the pudding!
    Danke !
    -Allen-
    Senior Member MikeyC's Avatar
    Nov 2015
    Oxfordshire, UK
    Curious also about the full-length black (rubber/plastic?) "ladder" gasket between the mounting studs on these grills. PET and my later cars ('68) show only a round washer on each of the studs, so I assume this ladder gasket is also a unique part with these early grills?
    Mikey C. ESR Membership #3333
    http://www.mceporsche.com
