Results 1 to 5 of 5
Thread: Aluminum S brake question
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    There is a tiny tube like bushing that fits around the pin in this photo. It was either missing or disappeared when I disassembled the caliper for a rebuild. Does anyone know where I might be able to buy another one?
    Name:  aluminum brake.jpg
    If you struggle to find any they are reasonably easy to make.
    They are a very slight interference fit into the steel bush that is attached to the back of the piston with a snap ring.
    They press-in and the groove helps keep them in place.
    They are a very slight clearance on the pin in the caliper body.
    Apr 2014
    New York/Florida
    Thanks for the info....but what purpose does this "anti-knock bush" serve ? Seems to be over engineered, or am I wrong? When I took the calipers apart,the retaining rings were loose and hanging on to the lower pin where it was pressed into the casting. The other question I have involves the rebuild kit for these calipers. The kit comes with the 2 dust covers , but only 2 seals...there are 3 seals in each caliper. Any explanation?
    Name:  alloy caliper parts.jpg
    Without the bushing the pads get knocked back from the disc and you get long pedal travel before the brake engages with the disc. Not a pleasant feeling when you need the brakes instantly.
