Results 1 to 10 of 11
Thread: 73 911 2.4mfi pop sound coming from exhaust help
    Mar 2015
    Orange Ca
    Hi I'm having this misfire(pop) sound coming from the exhaust not sure what it is
    Here's a link to a video I took
    My car is a 1973 911T 2.3 MFI
    https://youtu.be/gcYFnbM8Pbs
    One would call that a misfire. When was the last time you did a complete tuneup?
    Mar 2015
    Orange Ca
    Hi, the car had been stored for years, I did major service changed the
    spark plugs
    gaskets
    hoses
    clean out the gas tank
    new filters
    new electric fuel pump
    Only thing I didn't rebuild/replace was the Mfi pump & injectors
    What could be causing it?
    How about the plug wires?
    If not that, have the injectors cleaned and tested. Does it misfire while driving? Have you tested to see if the fuel mixture is ok?
    Mar 2015
    Orange Ca
    Do you know of a place that I can take my injectors to get tested?
    Haven't driven it on the street yet just warm it up once a week.
    Haven't tested the fuel mixture.
    I was looking for a shop to take it to because I'm not an expert on the Mfi.
    Does anyone know of a good place in socal?
    TLG or Scott's Auto. Both in greater LA area,,,,two of the best.
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    It appears to me a mixture issue. It could be a number of things....
    stuck rack
    lazy injector at idle
    linkage issue(s)
    Air Bypass screws plugged
    etc..
    Does the engine take throttle?
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Until he actually drives the thing and gives it a bit of a workout, he'll just be chasing his tail.
    Mar 2015
    Orange Ca
    Do you recommend driving it? Any risk of engine damage?
    When I give it throttle it revs fine just at idle that it has the misfire
    Mar 2015
    Orange Ca
    Thanks for your help guys
