Results 1 to 10 of 14
Thread: FS: '67- 911 Navigator's Light Base, 901.632.155.01
    This replaces the NLA part:
    PET '70-'73 911 Fig. 9-05-10, #56 901.632.155.01 Mounting plate (for Navigator's light) Qty: 1
    Earlier, these were a component of the SWB production option number 9182, Co-pilot’s interior Light.
    These lights were also described in the "Information Regarding Porsche Vehicles Used For Sports Purposes" brochure:
    • This is a rally-tested light with a flexible connection. The light can be bent to any desired angle and position and is a considerable help on night drives for map- reading, etc (can be fitted as a production Option).
    • Installation instructions: The light is screwed onto the right windshield pillar directly over the instrument panel. A holder for the flexible arm when not in use is bolted under the light fixing; this is also fitted on the windshield pillar.
    Mount:
    Material: Stainless steel, 304
    Finish: Glass bead-blasted
    Weight: 27 grams
    U-Clip:
    Material: Stainless steel, 0.5mm
    Finish: Mill
    Weight: 5.4 grams
    Purpose: Secures the light's spiral cable and it is commonly missing from used lights.
    Upgraded stainless steel fasteners are included:
    Oval-head sheetmetal screw, B 3.5x9.5 (attaches Mount to A-pillar) Qty: 3
    Oval slotted screw, AM 3x14 (attaches Light to Mount) Qty: 2
    Also required:
    PET '70-'73 911, Fig. 9-05-10, #55, 901.632.102.01 Interior light Qty: 1, NLA
    This light was made by Butlers (Flexilight, Navigator Model, #1589-P, 12V, 18" tube) & is frequently found used on eBay.
    N.B. Butlers also made a similar, 'incorrect' Executive Model, #1589/L, with the switch centerline axis perpendicular to the mounting screw axis
    The price of the assembly is $39.54.
    Shipping within the US is by your choice of USPS Priority Mail ($7.15), or Parcel Post ($3.00).
    Other items:
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    always when i saw this pic i was wondering what this thing mounted close to the passenger a-pillar is...
    you learn something new every day
    Fantastic item, Jimmy. All the details spot on as usual.
    PM sent for one.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Sep 2009
    UK
    Good stuff Jimmy, email sent.
    Dave
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Please send me two assemblies, if you ship overseas
    Can these mount in a 914?
    Dang that's cool.
    Dirk:
    Yes. I ship globally. PM sent.
    Larry:
    I have never seen them used on a 914, but they would fit.
    Aug 2012
    France
    Hi, is the mounting assembly still available ? If so I'd like one set please.
    Cheers
    X
    O-G 26 - Early911S 2407
    Hi Xavier,
    Sorry, but I sold the final one last week.
    Don't worry. I will make some more next week.
